IR Programing
 Posted: Saturday Dec 10th, 2016 12:42 pm
Swiss-Toni
It's been a long time since i have setup a IR, I have copied the TX from the remote via the ethernet UCM, that was fine.
The issue is when IR is connected to an output I cannot find the files I need to associate with responces in "Responce Wizard"
Cannot remember how I done it before, Am I missing out on the programming as cannot find in manual for programing IR in "Responces"
:shock:
 Posted: Saturday Dec 10th, 2016 01:28 pm
Online
when you learn an ir code it goes into the IR Library
You have to go to Configuration > IR Transmit Codes to select the IR code that you learned
The pulldown menu allows you to select the code that you learned
see the topic here
How to Send Infrared Signals through any Output
http://comfortforums.com/forum126/4395.html
 Posted: Saturday Dec 10th, 2016 03:20 pm
Swiss-Toni
Thankyou for your responce, that was what I was doing!I have found that the IR will not work with my LEM01 and had to move it to No 16 Output in the main panel and it worked as it should.
Is their any known issues with using IR conected to Outputs beyond output 16?
Prior to putting it on Output 16 I tried to have connected to Output 21.
 Posted: Saturday Dec 10th, 2016 03:32 pm
Online
Output 16 is on LEM01 not on main panel
Output 21 should be on the Slave (SEM)
Do you mean it could not work on the SEM? what is the firmware of the SEM?
 Posted: Saturday Dec 10th, 2016 03:45 pm
Swiss-Toni
I stand corrected, It does not work on the SEM the firmware version is curently 6.068
(Also Output board working fine with relays)
 Posted: Monday Dec 12th, 2016 05:17 pm
Online
There should be no problem with SEM 6.068 sending IR codes
Can you send your cclx file to support@cytech.biz?
 Posted: Thursday Dec 15th, 2016 01:57 pm
Swiss-Toni
Hi SlyChiu
I noticed quite a few issues on my system where the IR was concerned and downgraded the use of comfigurator until it was working fine, Although admittedly I have not moved the IR back to the SEM as everything is working (if it isnt broke dont fix it rule) Not sure what was causing the issues as KT03 (the output signals)keypads were affected as well, I think there must have been a corrupt file somewhere along the line.
 Posted: Sunday Feb 4th, 2024 08:05 am
Online
Saved Infrared Codes may be found in the folder C:\ProgramData\Cytech\Comfigurator\ifr
 Current time is 08:08 am
