Output Actions
 Posted: Thursday Jul 30th, 2015 04:17 pm
The Output Category contains all the actions involving Outputs
Pulse Output
Activate Siren
Activate one of the 20 Siren Types. Select a Siren type to activate
All Outputs off
Turn off all outputs on Comfort, Slaves and Local Expansion Modules
Bell Output
Switch the Bell (Siren) Output On or Off
Blinds Operation
Select the  Blind # (1 to 8), Operation Stop, Up or Down
This refers to the Blinds Function in Functions
Get Output State
Get the value of the selected Output number. The value is 0 for off, or 1 for On. This value is used in the next Action "If Last Action Value"
eg
Get Output 1
If Last Action Value =0 Then
Else
Endif
Infrared Command
Any Infrared code in the IR Library (Configuration > Infrared Transmit Codes) can be selected to be transmitted to any Output in Comfort. An Infrared Transmitter (IRM01, IR01W, IR03W) must be connected to the selected Output and pointed  at the Infrared Receiver. IRM01 is for longer distances (8 meters line of sight). IR01W is for short range 1 meter, IR03W is a stick-on IR emitter to be pasted over the IR receiver and comes with a visible RED led to show transmission
Select the IR Code Name and Output
Open Door
Open the door or gate of the Door station with DM02
Select DM02 ID 1 to 3, and Pulse time in 10 ms units
This response can be used in the Open Door or Open Gate Response in Events > Misc Events
Set Output
Select the Output #, and operation On, OFF, Toggle, Pulse 1 sec, Flash
Flash Output will cause the output to alternate on and off at 2 second interval until an Output on or off command is sent to the same output
Siren Off
Turn off the active siren type
Strobe Output
Control the Strobe output. Select On or Off
Switch Aux Supply On/off
Control the S12V Output (Switched 12V) On or off. This is normally used to switch the S12V off to reset Smoke or heat detectors  after they have been activated
This can be in a Response assigned to the Security Off Response or Home Control Menu
Toggle Output State
Toggle the selected Output ie change the state of the output from off to on or vice versa.
 Current time is 03:06 am
