Comfort Automation/ Security System Forums > Products > Expansion Modules > Local Expansion Modules - Zone Numbering
 Posted: Sunday Aug 4th, 2019 07:11 am
Local Expansion Modules are connected directly via a Ribbon cable to  either a Comfort Main board, or Slave. Only 1 LEM can be connected to a Comfort or Slave There are 3 types of LEMs;
LEM01B with 8 inputs and 8 Outputs
LEM01 Inputs and Outputs are numbered as follows
  • 9 to 16 when connected to Comfort
  • 25 to 32 when connected to Slave #1
  • 41 to 48 when connected to Slave #2
  • 57 to 64 when connected to Slave #3
LEM02B with 8 Inputs, 0 Outputs
LEM02B is mounted direct onto the CM9001 PCB
LEM02 Inputs  are numbered as follows
LEM03 with 16 Inputs 0 Ouptuts
LEM03 Inputs  are numbered as follows
  • 9 to 24 when connected to Comfort, and no Slaves connected
  • 25 to 40 when connected to SEM #1, and no Slaves at a higher ID connected
  • 41 to 56 when connected to SEM #2, and no Slaves at a higher ID connected
  • 57 to 72 when connected to SEM #3, and no Slaves at a higher ID connected
  • 73 to 88 when connected to SEM #4, and no Slaves at a higher ID connected
If an LEM03 is connected to Comfort, Slaves cannot be connected, hence a Comfort + SEM03 is limited to 24 Inputs and 8 outputs
From SEM 7.118 firmware ionwards, LEM03 can be connected to the SEM with the higest ID in the system. Only 1 LEM03 is alllowed per system
Installation Instructions for the LEMs are in the Comfort Intsllation Manual which can be downloaded from the Cytech website
http://www.cytech.biz/installation_manual.html
Seer http://www.comfortforums.com/forum140/5092.html for more info on Local expansion Modules for CM9001
 Current time is 04:03 pm
