Comfort Automation/ Security System Forums > Products > Expansion Modules > Automatic Detection of LEM03 in Comfort
 Posted: Sunday Apr 16th, 2017 12:17 pm
From Comfort Firmware 7.117, Comfort will detect if the LEM03 is connected to it see http://www.comfortforums.com/forum79/4673.html
The checkbox  in Comfigurator > Configuration > Modules and Settings > LEM03 (24 Zone) can be ignored. After reading from Comfort this setting will show if LEM03 is connected or not, so it will be a Read Field. Writing into the LEM03  checkbox has no effect. The LEM03 state can only be seen after reading from Comfort
Attachment: lem03Box.JPG (Downloaded 68 times)
 Posted: Monday Apr 17th, 2017 07:10 am
SEM 7.118 firmware can also detect that a LEM03 is connected to it. This allows LEM03 to be used with Slaves Firmware 7.118 and above
The LEM03 need not be connected only to the main Comfort controller.
However LEM03 should only be connected to the LAST SEM. Connecting LEM03 to a lower ID SEM when there is a  higher ID SEM will cause the zones on the LEM03 to conflict with the zones of the Higher numbered SEM
See  http://www.comfortforums.com/forum78/4562.html for SEM 7.118 firmware
 Current time is 09:04 pm
