Comfort Home Automation/ Security System Forums > Products > Expansion Modules > Need to remove LEM from main baord - plastic standoffs
 Rating:  Rating
 Posted: Monday Oct 13th, 2014 12:42 am
MDKKEN
I need to get access to TEL IN, TEL OUT on main board to add the ADSL board, however LEM board with plastic stand offs is in the way. How to undo/remove the plastic stand offs? The metal standoff had screws that you could undo etc? I can not break the standoff?
 Posted: Monday Oct 13th, 2014 06:13 am
tech07
You can remove the LEM from the plastic standoffs by squeezing the top until the PCB can come out
Later versions of LEMs come with threaded standoffs
 Posted: Monday Oct 13th, 2014 10:23 am
What I did on mine is to buy some nylon threaded standoffs from Maplins in the UK.  Not sure what length you need but these and then put nut on the end.
http://www.maplin.co.uk/p/maplin-hexagonal-threaded-spacer-20mm-10-pack-qt82d
http://www.maplin.co.uk/p/maplin-hexagonal-threaded-spacer-12mm-10-pack-qt80b
http://www.maplin.co.uk/p/maplin-hexagonal-threaded-spacer-6mm-10-pack-qt78k
 Current time is 07:49 pm
