Comfort Home Automation/ Security System Forums > Products > Expansion Modules > difference between the master unit and Slave uit
 Posted: Sunday Feb 12th, 2012 02:50 pm
mikegriff
Is the left hand board the same as the master unit?
i.e can you flash a Master board to be a Slave board
I ask as as I have ended up with a spare main unit and need a slave.
Mike
 Posted: Sunday Feb 12th, 2012 03:43 pm
The hardware of the SEM and Comfort on the left are the same but the firmware is different
The firmware upgrading process only allows firmware of the same type to be upgraded as this may lead to problems and mistakes where the wrong firmware is flashed into a product
Hence you will not be able to "upgrade" a Comfort ffirmware into a Slave or vice versa
 Posted: Sunday Feb 12th, 2012 05:18 pm
mikegriff
I thought that might be the case
a wise move as well
Mike
 Current time is 07:28 pm
