KT03 Upgrade failed from 7.072
 Posted: Monday Aug 1st, 2016 11:28 pm
srooks
I was unaware of the upgrade bug in 7.072 and tried to upgrade via Comfigurator/UCM to 74. This failed and the KT03 now appears dead. No LEDs lit.I tried to upgrade directly from ETH3UCM using a programming cable but this doesn't work, again no LEDs visible when plugged in.
Help!
 Posted: Tuesday Aug 2nd, 2016 06:35 am
The UCM firmware cable upgrade should work
How did it fail? what are the error message
can you copy the I/O monitor during the fiurmware upgrade by cable?
How did you even find that  firmware 7.072? It was removed from the server
 Posted: Tuesday Aug 2nd, 2016 03:47 pm
srooks
The KT03 seems bricked. None of the LEDs are lit.
Is there a way to determine if it's actually running or not?
Thx
 Posted: Tuesday Aug 2nd, 2016 04:00 pm
If the firmware upgrade was not succesful none of the leds would light up. If it failed because of 7.072 upgrade then the hardware should still be working
What happens when you start the firmware upgrade by cable after connecting the 6-way cable? remove the other green terminal blocks from the back
 Posted: Tuesday Aug 2nd, 2016 11:34 pm
srooks
I now have it working, using the UCM to program, I couldn't get it working using 7074 - comfigurator gave me an error , "Firmware upgrade encountered errors."
I was able to use 7032 and then go from this to 7074.
Thanks for your help!
 Current time is 12:11 am
