Pending Messages button
 Posted: Tuesday Mar 20th, 2012 09:30 pm
rodime
Assuming use of the common mailbox - Is there a way to program a button to KT03 homepage that will, without signing in -
1. Show status if there are waiting messages on the answerphone (similar to flashing led status) and/or
2. Jump straight to message menu.
Alternatively, if sign in cannot be bypassed for common mailbox, on sign in if there are unread messages, is there a way to jump immediately to a page where I can then display message menu buttons specifically designed to look like answerphone buttons as opposed to the keypad display.
 Posted: Wednesday Mar 21st, 2012 01:25 pm
You need to sign in as this is the only way to know which user it is.
In KT03 configurator, you should start with the template supplied - Load Template and select kt03def.kt3x This loads the predefined pages which you can modify as you wish
There is no visual display of messages available - the flashing MSG LED would be best for this purpose.
You can add a button with the KeypadKey Keyhash which is like the # key. This announces "New Message for .." when there are new messages
To go to mesages menu you can program a function key to go dorect to the messages menu (Keypad Menu Messages)
Then program a button to activate the functiion key. This will directly go to the messages menu
 Current time is 11:22 pm
