Setup screen icons are static
 Posted: Monday Dec 12th, 2011 02:43 am
I noticed in the Setup screen that all the icons are static. The Speaker, IR, Backlight and Screen icons don't change when you tap them. Is this by design or perhaps an oversight?
I also noticed that Active/Inactive text overlap EG. If you have an Inactive label like 'Ok' and an Active label as 'Trouble' then while all is normal the 'Ok' text is displayed but parts of the Inactive label is shown below the Active label. An example would be 'Phone Line OK e' which I assume would be 'Phone Line Trouble' or something displaying underneath. The same goes for other texts in the 'Trouble Conditions' screen.
 Posted: Monday Dec 12th, 2011 04:11 am
HeFeng
Hi, Ingo, Setup page is system page , currently icon is fixed,
but you can see text "on" and "off" while touching with different state...
for active/inactive text overlap, can you send your cclx file to us for checking? thanks!
 Posted: Monday Dec 12th, 2011 03:27 pm
Thanks HeFeng, I can see that the Active and Inactive text must fall inside the boundaries of the text box otherwise it overlaps.
Regards,
 Current time is 11:04 pm
