Button changed position
 Posted: Saturday Nov 5th, 2011 08:25 am
reyhaneh
After writing to KT03 when I pushed one of the buttons it worked but disappeared from the screen.Why this happened?
BR
 Posted: Saturday Nov 5th, 2011 08:32 am
This should be due to the way you programmed the button
Can you send your file to support@cytech.biz and tell us which button caused the problem?
 Posted: Saturday Dec 31st, 2011 05:58 am
This problem may be the one which was solved in Comfigurator 3.4.3 (beta), see http://www.comfortforums.com/forum20/2657.html
The symptom is when you move buttons around on a page, in Comfigurator, the software becomes slow and unresponsive and when you clock on a button, it flies away. The Properties on the right becomes black on every page until you save and reload the cclx file
This is due to a memory leakage problem which was fixed in Comfigurator 3.4.3
 Current time is 01:19 am
