UCM/KNX2 7.087 to 7.097
 Posted: Monday Aug 7th, 2017 04:30 pm
KNX 7.087
Bugs
  1. Date and Time from KNX (when mapped to KNX) did not get sent to Comfort
Bugs Fixed
  1. Fixed Bug - bypass zone to KNX did not work
  2. Fixed bug on Bypass zones to KNX
  3. Fixed bugs in security modes to KNX.
  4. Fixed bugs in EIS10 2 byte counter, EIS5. sFixed bugs in EIS10 2 byte counter, EIS5.
  5. Fixed BUG: Action send command to KNX does not update Comfort register which is mapped to the KNX address
Changes
  1. Even if counter> KNX 1 bit programmed, send to KNX > Comfort 1-byte group address if present. Even if counter> KNX 1 byte programmed, send to KNX > Comfort 1 bit group address if present
  2. When sensor value changes, send sensor value to mapped KNX address KNX to Comfort mapped to Comfort sensor.
  3. When security mode changes, send value to KNX to Comfort for security mode group address.
  4. Added Status Message  "invalid physical address"
  5. UCM/KNX2 Status Error will appear if no confirmation for telegram to KNX.
  6. Improved status report to Comfigurator
  7. If no EEPROM, flash ERR LED
UCM/KNX1 firmware 7.079 can be upgraded to UCM/KNX2
 Posted: Tuesday Aug 8th, 2017 01:37 pm
eborges
I'm currently running my UCM/KNX2 on 7.097 Beta . I don't understand why a UCM/KNX2 7.089 is being released now with an inferior version number. Is it a typo ? Should it be  version 7.098 instead?
 Posted: Tuesday Aug 8th, 2017 04:30 pm
Actually we did not give the release notes for 7.087 so we are belatedly doing that now
7.097 is the latest Beta, which also does not have release notes of the changes for some reason. I will check what has changed in 7.097
 Posted: Wednesday Aug 9th, 2017 06:29 am
UCM/KNX 7.097
Bugs fixed
  1. Send date and time from KNX did not work
Changes
  1. Speed up write to EEPROM by 30% by checking a block eeprom before erase
  2. at reset, all comfort zones are reported to KNX when Alarms to KNX > Zones Status is mapped to KNX. However there must be consecutive KNX 1 bit addresses corresponding to all programmed zones, otherwise there will be unacknowledged telegrams on the KNX bus
 Current time is 09:17 am
