Posted: Wednesday Feb 20th, 2013 11:04 am |
KNX 6.111 (beta) has the following changes- Fixed BUG from KNX 6.024 - KNX to Comfort mapping for Keypad Keys, Arm commands, Panic, Bypass Zones, and Zones did not work. Map to Counters, Sensors, Virtual Inputs do work
- Function to use COPY button to press and hold to change UCM/KNX ID has been implemented. However this only affects UCM/KNX which has the pushbutton available.
KNX 1 bit and 1 byte objects mapped to Comfort Counters are ignored if the value is unchanged, eg On command folllowed by another ON command, or Off comand followed by another off command, or the same value in a 1 byte object
Posted: Wednesday Feb 20th, 2013 11:37 am |
For KNX 6.111, KNX 1 bit and 1 byte objects mapped to Comfort Counters are ignored if the value is unchanged, eg On command folllowed by another ON command, or Off command followed by another off command, or the same value in a 1 byte object
The above behaviour of KNX6.111 was introduced in KNX6.024. In the previous firmware 6.015, 1-bit and 1 byte objects always updated the mapped counters even if their value does not change. It has been pointed out that this is better because KNX Scene buttons must send the same value when they are pressed
hence we have also a version 6.112 which behaves in the "old" way ie like 6.015, in the attached file
When we have feedback as to the best way to implement this then future firmware will be fixed in that behaviour
The two versions 6.111 and 6.112 otherwise are the same
Known Bugs
Sending telegrams to KNX group addresses causes the mapped counter to be updated for status but it should not cause Countter Responses to be activated. The bug is that counter Responses are activated by telegrams to KNX.
Counter Responses should only be activated by telegrams from KNX to Comfort
Attachment: KNX6_112.zip (Downloaded 37 times) Last edited on Monday May 13th, 2013 12:14 pm by ident
Posted: Saturday Feb 23rd, 2013 02:39 am |
It appears that KNX 6.112 is preferred. That is the one where KNX telegram with the same value will actiivate counter Responses
It is working
Posted: Friday Mar 1st, 2013 05:54 am |
KNX firmware 6.112 haas been released
Pllease upgrade if you have problems with older firmware
Posted: Monday May 13th, 2013 12:17 pm |
Please note the bug found in KNX 6.112
Known Bugs
Posted: Thursday May 16th, 2013 05:39 pm |
TheMax74
Posts: | 247 |
This can cause an endless loop
Posted: Friday May 17th, 2013 02:23 am |
It should not cause an endless loop
Lets say you send a telegram to KNX group address. The counter is updated and activate a Response. This should not cause a telegram from KNX which would cause an endless loop
Now the case where a telegram is received from KNX which activates a counter response. That Response should not send a telegram back to the same KNX group address as that would be wrong and unnecessary. if a KNX address is switched ON, you dont want to send a telegram to switch it on again, or switch it off again
Nevertheless there may be undesirable effects in certain cases. A new version wil be released soon
Posted: Monday Nov 18th, 2013 08:37 am |
dohongson
Posts: | 1 |
Can I use the UCM/KNX module to program the Comfort System via KNX bus without a standard UCM?
Posted: Monday Nov 18th, 2013 10:03 am |
cleaner
Posts: | 23 |
You cannot use UCM/KNX to program Comfort, it function is to interface with KNX only
You use UCM/USB or UCM/ETH02 to program comfort, prfer UCM/ETH02 because it can program from remmote and can use iphone /android app with it
Posted: Saturday Apr 19th, 2014 01:55 pm |
TheMax74
Posts: | 247 |
ident ha scritto: It should not cause an endless loop
Any news about new version ?
Posted: Saturday Apr 19th, 2014 03:59 pm |
Sorry about that, there is a beta firmware 7.030 which you can download from http://www.cytech.biz/product_details.php?item_id=232 that should fix the problem of sending command to KNX also updates the mapped counters response
In most cases that bug should not affect you so you may not see any difference
Posted: Tuesday Apr 22nd, 2014 06:55 pm |
Posts: | 771 |
Chiu
Yet another reason to RENAME the UCM
How about ANY UCM that can upload / download Comfigurator to be re-named CCM (Comfort communication module) ?
Posted: Saturday Apr 26th, 2014 10:09 am |
If we were starting over with the names of modules, that would be a great idea, but I am worried that it may cause confusion if the name of the most commonly used module were changed now
