UCM/KNX Firmware
 Posted: Tuesday May 25th, 2010 01:16 pm
KNX 5.203 (30 April 2010)
New Features
  1. added Zone Not Ready 1 byte object with value of zone number
Bugs Fixed
  1. Arm Ready 1 bit group address does not work
Known Issues
  1. KNX relative dim levels are wrong when SCALE switch is shunted
  2. KNX Floating point EIS5 calculation wrong
  3. when any Comfort Trouble condition is restored, the Rs485 communications failure affects the AC Fail condtion for the Mapped KNX group address. Hence if Comms fail is restored, so is AC Fail
  4. Mapping of KNX group addresses to Counters > 128 do not work. Please keep to counter numbers < 128
  5. When a Zone Trouble condition is seen by the KNX mapped group address, another zone on or off will clear the KNX Zone trouble condition
  6. Date to KNX may be wrong
  7. If Slave is installed, Bypass Zone mapping to Group address does not work
  8. When a zone is bypassed on Comfort the Bypass state of the zone is not sent to KNX
KNX 5.195 (Initial Release 4 August 2009)
Known Issues
  1. Mapping of KNX group addresses to Counters > 128 do not work. Please keep to counter numbers < 128
  2. Arm Ready 1 bit group address does not work
  3. Date to KNX may be wrong
  4. If Slave is installed, Bypass Zone mapping to Group address does not work
 Current time is 09:26 pm
