Comfort Automation/ Security System Forums > Third Party (interfacing to Comfort) > Velbus > The lights are on or off in the Comfort app for android
 Posted: Wednesday Dec 27th, 2017 12:51 am
Draco
Hello,
I'd like to know how to see if the lights are on or off in the Comfort app for android applied to Velbus System.
I don't know what is wrong with my programming. Is there any possibility to work with colours and, for example, when the words turn green, lights are on and when they turn red they are off? Or is there any other possibility of programming so I can distinguish if the lights are on or off? Can you help me?
Many thanks,
Rui Oliveira
Attachment: Screenshot.zip (Downloaded 1 time)
 Posted: Wednesday Dec 27th, 2017 06:13 am
Velbus status can be obtained using the Control Key Feedback register. It should be mapped to Counters or Flags etc
If you have configured your control menu correctly, you should be able to see the status of the vebus devices via the comfort app
 Posted: Saturday Dec 30th, 2017 11:37 am
Draco
Hello
I'd like to thank you for your tips. The problem with the lights is solved. Unfortunately, as I have structured the whole control menu I got two other problems: one of the sunscreens had a memory crash (and I can't control it even when I return to the old settings) I must check the motor of the sunscreen (first I had it down and it would go up all by itself, now I can't control it at all). The other sunscreens go up and down but the same doesn't happen to the blinds. Although they are programmed the same way, I can't control them through the android app. Any tips for the blinds?
Again, many thanks for your help.
Best regards,
Rui Oliveira
 Posted: Sunday Dec 31st, 2017 10:25 am
we will need to look at the cclx file to see what has bveen programmed
Please send to support@cytech.biz and indicate which control menu has this problem
 Current time is 01:49 pm
