Posted: Thursday Jan 27th, 2011 11:20 am |
bs85
Posts: | 90 |
When are you going to add support for the new Velbus modules?
VMB4RYLD - 4 Channel Relay Module
VMB4RYNO - 4 Channel Relay Module
VMB4DC - 4 Channel 0-10V Controller
VMB1LED - LED Dimmer Module
Posted: Friday Jan 28th, 2011 12:28 am |
The 2 relay modules are similar to the exiting relay modules which we support, so it should be quite simple to add support for these.
The 0 to 10V and the LED dimmer will need further study
Do you have a pending requirement to use these new modules?
Posted: Saturday Jan 29th, 2011 08:31 am |
bs85
Posts: | 90 |
I have some LED dimmer modules on order.
So support for these would be appreciated.
Posted: Saturday Feb 5th, 2011 11:07 am |
bs85
Posts: | 90 |
I have received a couple of VMB1LED modules.
When doing a learn with the VMB1LED modules connected it fails with a No response to Velbus Learn Request.
When added manually as VMB1DM modules they work OK.
Posted: Monday Feb 7th, 2011 12:30 am |
Comfigurator does not recognise the module type of VMB1LED because it was introduces after the UCM/Velbus became available but as most of the commands are the same as VMB1DM it should work
In future we will add support for the new modules. We are waiting for our order of the modules from Velleman so we can test
Posted: Thursday Apr 7th, 2011 05:28 am |
bs85
Posts: | 90 |
Any updates on adding the newer modules?
Posted: Monday Apr 18th, 2011 05:18 am |
UCM/Velbus 5.229 can be downloaded from the website at http://www.cytech.biz/ucmvelbus_firmware.html which supports the new Velbus Modules
This is labelled a Beta version at the moment
It fixed the problem in previous versions that sometimes when learning the Velbus network, an error message is seen, even though the network is scanned correctly
Posted: Monday Apr 18th, 2011 08:26 pm |
bs85
Posts: | 90 |
Got 5.229 firmware installed and still getting the "No response to Velbus Learn request" every time a learn is run.
Posted: Tuesday Apr 19th, 2011 04:11 am |
You are right, there is still a problem which is being looked into
Posted: Wednesday Apr 20th, 2011 01:48 am |
Posted: Thursday Apr 21st, 2011 08:01 am |
Posted: Wednesday Jun 15th, 2011 02:58 am |
