Posted: Saturday Mar 20th, 2010 05:08 am |
Posts: | 5493 |
We have developed an interface to the Velbus http://www.velbus.eu/ with a range of modules for switching, dimming, curtain control, temperature sensing from the Belgium manufacturer Velleman.
Velbus is an extremely reliable modular automation system. All modules are interconnected by means of a 4-wire bus. There is no master controller. A typical system consists of two basic types of modules: input and output modules. Input modules translate information from the outside world (e.g. pushbuttons, switches, sensors, etc) to bus commands. Output modules interpret these bus commands and in turn control lighting, heating, ventilation, outlets, shutters etc... Feedback-LEDs on the input modules show the status of the output modules. A basic Velbus application requires one input and one output module. Applications: Home, office or industrial automation, process control, etc...
This is a lower cost product compared to KNX and C-Bus etc and may be a good solution in more cost sensitive projects
The Velbus interface is supported in Comfigurator 3.2.8
The Velbus Configurator is in the Modules tab. Add UCM > Velbus.
This allows Comfort to send commands to the Velbus modules and allows velbus modules to send status and commands to Comfort counters. as well as temperature information to Comfort sensor registors.
Up to 512 Velbus channels are supported
The Velbus Modules supported currently are- VMB1BL - 1 channel Blinds
- VMB2BL - 2 channel Blinds
- VMB1RY - 1 channel Relay
- VMB4RY - 4 channel Relay
- VMB1DM - 1 channel Dimmer
- VMB4PD - 4 button Pushbuton Module
- VMB6IN - 6 input Module
- VMB8PB - 8 button Pushbutton Module
- VMB1TS - Temperature sensor
- VMB1TC - Temperature Controller - NEW
- VMB1LED - Professional LED Dimmer Module NEW
- VMB4RYLD - Programmable 4 channel Voltage Out Relay Module NEW
- VMBRYNO - Programmable 4 channel Relay Module NEW
- VMB4DC - 4 channel 0 (1) to 10V Output Controller NEW
- VMB4DME - Dimmer for Electronic/ Resistive Load NEW
New modules will be supported as they become available
The UCM/Velbus is has a Rs232 interface with a male connector so it can be connected directly to the VMB1RS Velbus Rs232 interface using a Male to Female RS232 cable - UPDATE: the VMB1RS Module is no longer needed! New UCM/Velbus connects directly to Velbus- see http://www.comfortforums.com/forum88/2302.html
Minimum Comfort Firmware 5.215
Minimum UCM/USB/232/Eth firmware 5.212
Minimum Comfigurator 3.2.8
UCM/Velbus firmware Velbus 5.230 download from http://www.cytech.biz/ucmvelbus_firmware
The UCM/Velbus Manual can be downloaded from http://www.cytech.biz/ucmvelbus_manual.html
Attachment: ucmrs232-2 small.jpg (Downloaded 191 times) Last edited on Tuesday Jun 14th, 2011 12:37 pm by
Posted: Friday Mar 26th, 2010 12:39 pm |
cgiltrow
This is great news. I have been playing with Velbus for a while. They are great products at a reasonable price point.
How can I go about getting a unit to test with?
Cheers,
Clinton.
Posted: Friday Mar 26th, 2010 12:46 pm |
Posts: | 5493 |
You can go ahead to order the UCM/velbus from your usual distributor. However note that the fiirmware is not released yet, but you can easily upgrade the firmware later with a UCM. The UCM/Velbus is priced the same as a UCM/232 for now
Posted: Thursday Apr 8th, 2010 01:11 pm |
The UCM/Velbus has a Learn button in Comfigurator.
After configuring the velbus modules using its own software, assigning the IDs and behaviour, press the Learn button to get the information of the Velbus IDs and names into the Velbus to Comfort Module.
If the UCM/velbus is not connected to velbus, ie you are offisite, then you can manually add the modules and assign the IDs but this is not recommended. Always use Learn as far as possible so that the Ids etc are correct, to avoid the posssibility of mistakes
Posted: Thursday Apr 8th, 2010 08:43 pm |
Billan
Posts: | 21 |
The UCM/Velbus is the same as UCM/232?
Posted: Friday Apr 9th, 2010 01:55 am |
No, the UCM/Velbus is not the same as UCM/232 although they look the same. The UCM/Velbus understands the Velbus protocol and can communicate with velbus in 2 directions via the VMB1RS
Posted: Sunday Apr 11th, 2010 09:08 am |
A new Forum has been started for this impprtant Velbus interface at http://www.comfortforums.com/forum88/.
Please post any comments, questions or feexdback in this forum as a new topic
Those who are interested in Velbus should Watch this forum. Go to Menu > My Account, and select Watched Forums. Check the Velbus forum and well as other forums you would like to Watch, then press Save.
You can opt for send emails as they come in or as Daily digest
Posted: Saturday Aug 21st, 2010 02:32 am |
