Posted: Monday Nov 14th, 2016 05:38 pm |
Posts: | 5498 |
Known Issues- In Flags screen, if Check Status box is checked for a flag, the status is updated, but if the flag changes subsequently, the flag status in the centre pane is not updated until you go to another page and back, or uncheck and check the box (old bug)
- In Modbus configurator, Sensors cannot be mapped to Modbus
- for TSM, if older firmware eg TSM 7.001 has read from EEPROM, this may cause an exception. Workaround is to upgrade TSM to the latest (7.003) firmware first
Bugs Fixed- "If Input" comparison action did not work for Input > 64 to 96. This also applies for older versions
- Deg C /deg F in Comfiguration flags is incorrect
- Comfort Optimum when adding UCM/KNX2 caused exception
- Read from KP06A or KP04A does not change the KP06A/KP04A settings in Comfigurator
- IRIO IR codes do not refresh when new IR codes are learned. Refresh button is needed
- Default template def40.cctx for UCM/Logic is missing from the installation.
- Export Scenario dis not work. Selecting any items will cause an exception
New Features
TSM01- Added parameters; Heating / Cooling Mode, Virtual Input, Heating/Cooling Output, Virtual Alarm Offset, Calibration Offset. This implements the Temperature Alarm Monitoring feature which maps to Virtual Input to trigget the Temperature Alarm. New Temperature Alarm Type, TempNO Zone Type added to defaults.
HIO- Added Lighting Sequence Timer Parameter for delay between each light turning off in Occupancy Detection Mode
IRIO- Added Resistive Sensor Input Functions
UCM/Modbus
Supports the new UCM/Modbus. New Product will be announced soon
Posted: Wednesday Nov 30th, 2016 05:14 pm |
Posts: | 5498 |
Comfigurator 3.11.9 has been released
Please take note of the known issues in the 1st post
Posted: Saturday Dec 3rd, 2016 01:58 pm |
burtonjk
Posts: | 22 |
Receiving the following error after updating to 3.11.9:
System.NullReferenceException: Object reference not set to an instance of an object. at Comfort.MiscellaneousEvents.get_ShowPartition()
Anyone any ideas?
JimLast edited on Monday Dec 5th, 2016 09:19 am by
Posted: Sunday Dec 4th, 2016 06:39 am |
Posts: | 5498 |
can you send the cclx file to support@cytech.biz?
something in the file seems to be not compatoible with partitions
Posted: Monday Dec 5th, 2016 06:49 am |
burtonjk
Posts: | 22 |
Thanks Chiu. File sent. I did try going back to 3.11.6, unchecking load last file, then re-installing 3.11.9, but no joy with that, same exception error.
Jim
Posted: Monday Dec 5th, 2016 06:56 am |
Posts: | 5498 |
we do not get the exception with your file
Does the error appear when you start comfigurator or when you load your cclx?
Posted: Monday Dec 5th, 2016 07:45 am |
burtonjk
Posts: | 22 |
I get the error when starting Comfigurator. IE with an untitled cclx.
Posted: Thursday Dec 8th, 2016 06:06 pm |
Posts: | 5498 |
we have not been able to duplicate the exception but we believe this new beta version 3.11.10 should fix that problem
Please upgrade from http://www.cytech.biz/product_details.php?item_id=206 and let us know the result
Posted: Friday Dec 9th, 2016 05:29 pm |
burtonjk
Posts: | 22 |
3.11.10 has fixed the problem. All good now, thanks
Jim
Posted: Saturday Dec 10th, 2016 06:38 am |
Posts: | 5498 |
Comfigurator 3.11.10 has been released
Bug Fixes- Fixes the exception "System.NullReferenceException: Object reference not set to an instance of an object. at Comfort.MiscellaneousEvents.get_ShowPartition()" when starting Comfigurator. This has been reported by some users.
- Fixed Bug in UCM/Modbus Sensors could not be selected
- Fixed Links to Manuals for HIO, TSM, IRIO, Modbus. Note there is a slight bug in Link to Modbus manual. When a new Modbus is added, the link is incorrect, but after the file is saved and reopened, the manual link works
- New version of Bus Monitor and IR Learner are included
- UCM/GSM4 - Spaces are automatically added to Zone Names, Alarm Names, User Names before capital Letters in SMS eg "FrontDoor" becomes "Front Door". This is needed because Comfigurator does not allow Spaces in Names. Also the UCM/GSM4 Properties shows the GSM module name eg 800, 900 etc which will cater for new models
- Default Responses - Fixed Error in Vibration Responses
Posted: Thursday Dec 15th, 2016 07:34 pm |
Swiss-Toni
Having problems with using ver 3.11.10
Its knocking out my KT03 keypads, similar to a issue with a different version of comfigurator pre-partioning ver.
The commands for alarms ect work however the keypad fails whe using a "output" command ie button for heating. the only way I could remedy this is to first use a version of comfigurator pre partioning Ver 3.9.7 and then use ver 3.11.6 to get my partions back and everything functioning again, through trial and error every time I have used ver 3.11.10 my KT03 keypads will not send commands for outputs....
Posted: Friday Dec 16th, 2016 06:07 am |
Posts: | 5498 |
Can yoiu give more details on this problem?
After upgradong to 3.11.10, one of the KT03 buttons does not work?
Did you write to Comfort and write to KT03 after the upgrade? If not there should be no change just upgrading Comfigurator
Downgrading to 3.9.7 fixes the problem, but what did you do after downgrading?write to KT03 and Comfort?
Please send thecclx file to support@cytech.biz and let us know which button does not work
Posted: Friday Dec 16th, 2016 12:49 pm |
Swiss-Toni
Will send CCLX file shortly, any button that opperates a output fails, and yes wrote to both comfort and keypads.....
Posted: Sunday Dec 18th, 2016 07:32 am |
Posts: | 5498 |
I dont think we have received the cclx file
