The changes in the beta 3.11.3 which mainly affect the IRIO are;
Known Bugs
- Actions for UCM/KNX2 are wrong. Use flags and counters instead to send telegrams to KNX
- In Flags screen, if Check Status box is checked for a flag, the status is updated, but if the flag changes subsequently, the flag status in the centre pane is not updated until you go to another page and back, or uncheck and check the box (old bug)
- Importing a Configuration Item from a file with a different file system causes exception (old bug)
Improvements- IRIO submodules selection are listed in Alphabetical order, ie ISM01, ISM02...
- IRIO Added Temperature Sensor Function function to submodules ISM01, ISM07. This requires an external TSM01 Thermistor and allows mapped sensor to rad the temperature.
- IRIO added Resistive Sensor Function to submodules ISM01, ISM07. This caters for any resistive type sensor eg Light, Pressure etc to be mapped to sensor.
- IRIO Added IR with Feedback Function to ISM03 Infrared submodule which uses Current sensor as feedback for the IR controlled device
- IRIO current sensor function added Mapping to Sensor as additional to Flag so the Sensor can be used to determine the current sensing level
- In UCM/Cbus2, when adding Group addresses the group address can changed so it does not need to add in sequence from low to high
The IRIO changes require IRIO firmware 7.004 see http://www.comfortforums.com/forum129/4460.html
