Comfigurator 3.10.1 to 3.10.2 (Beta)
 Posted: Wednesday Mar 25th, 2015 06:10 pm
Known Bugs
  1. For Heatmiser, read from EEPROM is blank but learning works. May be a  problem from Comfiguraut 3.7.6
  2. in KT03, selecting a few buttons and changing some visual attribute  may result in exception. But when the exception is cleared, the attribute is changed correctly
  3. KP06 Screen shows "Read from Keypad" and "write to keypad" which should not appear. Ignore these buttons
  4. From Comfigurator 3.9.5.  Read from Comfort will cause Functions > Thermostats to fill up the unused Thermostats with sensor 0 and assign Heating and Cooling Outputs to Output 1. You will not be able to control Output 1 after reading from Comfort.  In order to free up Output 1, unasssign the outputs from each Thermostat
Bugs Fixed
  1. For UCM/Zwave, the Virtual Node Info button was missing
  2. KT03 Button programmed to activate Response did not work - it sent Keypad key command instead
 Posted: Wednesday Mar 25th, 2015 10:55 pm
Notice (maybe I missed in earlier releases) some new settings for the KP06.
When I click "Read from Keypad" I get...
Attachment: KPError.png (Downloaded 64 times)
 Posted: Thursday Mar 26th, 2015 06:58 am
That is an error. KP06 should not have a Read button
This was mixed up with another product.
 Posted: Sunday Apr 12th, 2015 07:59 am
Comfigurator 3.10.2 (Beta) can be downloaded
The changes are
Bugs Fixed
  1. If KP06 Screen shows "Read from Keypad" and "write to keypad", this may happen if the cclx file was created using an older version. Rescan the keypads to remove these buttons
  2. Fixed bug From Comfigurator 3.9.5.  Read from Comfort will cause Functions > Thermostats to fill up the unused Thermostats with sensor 0 and assign Heating and Cooling Outputs to Output 1. You will not be able to control Output 0 after reading from Comfort.  In order to free up Output 0, unassign the outputs from each Thermostat
Known Bugs
  1. For Heatmiser, read from EEPROM to Heatmiser modules is blank but learning works. May be a  problem from Comfiguraut 3.7.6.  Workaround is to use Learn instead of Read from EEPROM
 Posted: Sunday Apr 12th, 2015 01:28 pm
slychiu wrote: ...Rescan the keypads to remove these buttons
I found I didn't need to do that as the settings Read/Write buttons are already gone post upgrade to this version.
 Current time is 03:56 am
