Comfigurator 3.9.4 - 3.95 (Beta)
 Posted: Saturday Oct 18th, 2014 12:50 pm
Comfigurator 3.9.4 Beta can be downloaded for testing from http://www.cytech.biz/comfigurator.html
Known Bugs
  1. The Zwave Configurator has undergone changes and is not tested. DO NOT use with ZWAVE till further notice
  2. Cbus2 Response Wizard - Trigger Application action selector 255 is not accepted since Comfigurator 3.8.6)
Bugs Fixed
  1. Slave Low battery message in Comfigurator alert text field shows Door station ID instead of Slave ID
  2. Cbus2 Configurator  - Limit Cbus  groups to 254
  3. When upgrading UCM/ETH or UCM/USB  firmware of the UCM which is directly connected to Comfigurator, and the upgrade is cancelled by pressing the Cancel button, the upgrade could not  be restarted due to errors. However if the upgrade is stopped due to other errors eg network time out or reply errors, the UCM upgrade can be restarted.
  4. In Velbus Response wizard, sending commands to VMB1RYNO, VMB4RYNO, VMB1DMI were incorrect.
Improvements
  1. Improved handling of Firmware upgrades to support UCM 7.060 to recover from failed Firmware upgrades even if the UCM were switched off or reset.
  2. Move "Convert cclx file for iOS/Android app" from HELP to File menu
  3. Keypad Broadcast Enable  action includes  "All keypads" to be specified in the action.
New Features
  1. Extend "Graph References" to include all relevant configuration items, ie Events; Zones , Counters, Flags, Alarms
  2. Changes to UCM/Velbus to support more modules and fix errors in commands to Velbus
 Posted: Tuesday Oct 28th, 2014 08:36 am
Comfigurator 3.9.5 Beta is now available
Known Issues
This supports new features in UCM/Zwave which will be described in the UCM/Zwave forum
UCM/Zwave 7.061 (beta) will support the new features from http://www.cytech.biz/product_details.php?item_id=288
Comfigurator 3.9.5 is released (31 October 2015)
 Current time is 05:20 pm
