Comfigurator 3.9.0 to 3.9.2 (Beta)
 Posted: Friday Aug 22nd, 2014 01:26 pm
The new beta version 3.9.0 van be downloaded from http://www.cytech.biz/comfigurator.html?category_id=98 for testing users
The main change is the introduction of the new highly anticipated Graph References feature
Known Issues
  1. in Cbus Module, writing to EEPROM without first logging in will cause scanning for modules to be repeated endlessly. The workaround is to log in or do a module scan first
  2. using Graph References on some responses , (eg 64,12, 1, 255) will cause an exception
Bugs Fixed
  1. Lutron commands for use in General and Universal UCM had error when more than 1 control Unit is specifed
  2. In Cbus2 Configurator, Read Properties for Cbus did not show the correct value of Resend Sim Options
  3. Sound types Tone 1 and Tone 2 limits has been changed 151 to 2400 Hz
  4. When doing Firmware Upgrade of KT03 by UCM, the PC is preveneted from going to sleep to allow the upgrade to complete
Graphical References
Right click on a Response and select "Graph References"
The graph references will look like this
Cursor over Node to see Tooltip
Double-click Response Node to make it the Target Response. Response node is shown with the lamp icon. Note that only a Response can be a target
Double Click the Target Response (in blue) to Edit the Response
Select a Response from the Responses page to change the Target Response
Help > Link to App Conversion Utility
This links to the Comfort app conversion utility
"Convert cclx file for iOS/Android app"
Comfort Server Manager
CSM 2.02 is included in Comfigurator, in Options > Settings, select Network (Local)
 Posted: Sunday Aug 31st, 2014 04:42 pm
mikegriff
I get this exception with some Responses when I try and view Graph Reference
the simplest response that does it is has these lines
Siren Ring
Say Zone Name
with action codes
64,12, 1, 255
Mike
Attachment: ver 3.9.0.0.JPG (Downloaded 54 times)
 Posted: Sunday Aug 31st, 2014 05:02 pm
Thanks, we confirm the exception and wil get it fixed
Note
The exception has been fixed in 3.9.1
 Posted: Wednesday Sep 3rd, 2014 04:51 pm
Comfigurator (Beta) 3.9.1 is now available for testing
The changes are:
Known Bugs
  1. Options for Firmware Upgrade to Comfort Control are disabled, hence Comfort firmware cannot be upgraded
Bugs Fixed
  1. in Cbus Module, writing to EEPROM without first logging in caused scanning for modules to be repeated endlessly.
  2. using Graph References on some responses , (eg 64,12, 1, 255)  caused an exception. However there may be other Responses which may cause exception
  3. Upgrading Firmware and Writing to KT03 via UCM/ETH03 used to have an error when the PC does to sleep due to the logn duration of these operations to KT03. The PC is prevented from going to sleep in the new version
Improvements
  • Graph Reference Objects are colour coded: The Target Response is in Blue, Other Responses are in Green, and other events, ie not Responses are in White. This helps to identify other Responses which can become the new target by double-clicking on it, eg see below
New Actions
Action 190 - Wait for Timer
eg, the following Response will  switch on the Corridor Lights, wait 10 minutes, switch off the corridor Lights, switch on the Landing Lights, wait 5 minutes, then switch off the Landing Lights. This requires Comfort Firmware 7.063
Response example:
Do CorridorLightsOn
Wait 600 Seconds Using Timer01
Do CorridorLightsOff
Do LandingLightsOn
Wait 300 Seconds Using Timer01
Do LandingLightsOff
Before the new action as introduced, this sequence would require 3 Responses, ie
1st Response:
Do CorridorLightsOn
Do 2ndResponse after 600 Seconds Using Timer01
2ndResponse:
Do LandingLightsOn
Do 3rdResponse after 300 seconds  Using Timer01
3rdResponse:
Do LandingLightsOff
Thus, this new action simplifies the programming of delays in Responses.
Note that the Wait for Timer action will not block any other Responses from working during the delay. For example a zone response will be activated if the zone is opened during any of the delays between the actions
Action 156 - Keypad Backlight On/Off
This requires Comfort Firmware 7.061
This turns on the backlight of any individual Keypad or all keypads. One use of this is to turn on the keypad backlight when motion is detected in the area at night, when lights are switched off
 Posted: Wednesday Sep 3rd, 2014 09:41 pm
Wouldn't the more logical place for the "Convert CCLX.. Android" menu action be on the "FILE" menu rather than the "HELP" menu as that's the first place I'd look.
 Posted: Friday Sep 5th, 2014 04:02 pm
Comfigurator 3.9.2 (beta) fixes the bug where Comfort Firmware upgrade was grayed out in the Modules Tab
 Posted: Friday Sep 5th, 2014 11:36 pm
TheMax74
Wow Great improvements! Nice job.
 Current time is 08:01 pm
