Comfigurator 3.8.9/ 3.8.10
 Posted: Saturday Jul 5th, 2014 08:18 am
The new beta version has the following changes and bug fixes
Known Issues
  1. RIO Input and Output status are initially shown by checking the "show status" box, but subsequent changes in RIO input and outputs are not updated
  2. Lutron commands for use in General and Universal UCM have error when more than 1 control Unit is specifed
  3. In Cbus2 Configurator, Read Properties for Cbus does not show the correct value of Resend Sim Options
Bugs Fixed
  1. Cbus1 actions which are not in the Lighting application were not converted correctly to Cbus2
  2. User Mode > Dial Test did  not work if the keypad name is changed.
  3. Options > Default KT03 Template caused  an exception
  4. Function Blinds > Show References do not work
  5. Keypad volume change did not get selected in "Selective Write".
New Features
  1. In UCM/CBUS2 Properties, a new setting "Resend SIM Options (seconds)"  to Resend the SIM optins periodically to Cbus, default 0 to disable. This require UCM/CBUS2 firmware 7.050 minimum
 Posted: Saturday Jul 5th, 2014 11:55 am
A "Display Manual" link stilling missing on UCM/HM properties page!
 Posted: Saturday Jul 5th, 2014 12:55 pm
It should be corrected in the next release
 Posted: Saturday Jul 5th, 2014 06:31 pm
Works for me. The missing buttons for some Cbus applications are now there and all my non-lighting applications are also migrated.
 Posted: Tuesday Jul 15th, 2014 01:05 pm
Comfigurator 3.8.10 has been released
This fixes some minor bugs in 3.8.9
Bugs fixed
  2. In Heatmiser, link to heatmiser manual has been added
Known Issues
  1. Lutron commands for use in General and Universal UCM have error when more than 1 control Unit is specifed
  2. In Cbus2 Configurator, Read Properties for Cbus does not show the correct value of Resend Sim Options
  3. For Write to KT03 by UCM, prevent the PC from going to standby as it may interrupt the KT03 write
  4. Sound types Tone 1 and Tone 2 limits is currently 150 to 2400 Hz. It should be 151 to 2400 Hz
Note
These may not be new issues, ie they may have existed in previous versions but not reported
 Current time is 12:57 am
