Posted: Saturday Apr 13th, 2013 05:08 am |
A New version of Comfigurator is now available on the Comfort server.
Upgrade from 3.6.x in Help Menu > Check for Updates
This mainly fixes bugs from 3.6.5
Bugs Fixed- For Zwave Configurator, the last line of Zwave Mapping is not written to EEPROM with the other lines, ie the assigned Comments and Comfort Register is not written to EEPROM. The workaround is to Read from EEPROM before adding the last line mapping and comments before writing to EEPROM
- For Zwave configurator, if a zwave node (virtual Node) is mapped to Virtual Input and the virtual node is removed, without first unmapping the Virtual Input, this causes the Comfort Zone/Input to remain as Virtual Node and this cannot be changed. Workaround is to unmap the virtual Input before deleting the Zwave virtual Node
- In Bus Monitor, if the Exit Button is pressed without first pressing the Halt button, the UCM will remain in Bus Monitor mode even though the Bus Monitor software has ended, and the UCM will not work normally, until the UCM is reset
- in KT03, copying the keypad Buttons Away, Night, Day arm buttons and pasting will leave the button actions empty, ie the button actions are not copied
New Feature
- The default files and templates can now be updated from the server in the File Menu > Update Defaults. The default files include templates for various models, vocabulary words and configuration files which are in the config folder in Comfigurator. This means the defaults can be updated without having a new Comfigurator release
Known Bugs
- Selective Write does not select Control Menu when Responses change which are assigned to the Control Menu. To workaround, please use Full WRITE. This may be a bug from older versions
- KT03 schedules - If Days of the week are checked the file saved and reopened, the days of week become unchecked. This is a problem with older versions as well
- If a KP04 with old firmware < 1.010 is in the system, a Module scan will cause a new KP04 to appear. Saving the file and opening again and scanning will cause anther phantom KP04 to appear. If the file is written to Comfort, a Communications Failure alarm occurs. The workaround is to delete the phantom KP04 every time after a module scan before saving. This wil be fiixed in the next Comfigurator
Posted: Saturday Apr 27th, 2013 03:30 am |
Comfigurator 3.6.8 has a few minor changes and will be available for download in Comfigurator Help > Check for Updates soon
The changes are- Zwave Configurator - removed Device Command and added Multilevel Switch Get and Multilevel Sensor get commands. These changes are needed for Zwave Certification
- Sentence Upgrade - if upgrade is interrupted because of a loss in connection (for Ethernet), "Continue from Last Address" will be seen. This allows the upgrade to continue without having to restart. This is already the case for ther full Vocabulary Upgrade as wel as firmware upgrade
Known Bugs- If a KP04 with old firmware < 1.010 is in the system, a Module scan will cause a new KP04 to appear. Saving the file and opening again and scanning will cause anther phantom KP04 to appear. The workaround is to delete the phantom KP04 every time after a module scan before saving. This will be fiixed in the next Comfigurator
Posted: Saturday Apr 27th, 2013 07:33 am |
You haven't updated the system so that 3.6.8 is advertised as a new version in "Check for Updates". It's on the website though I see so can be downloaded from there.
Posted: Saturday Apr 27th, 2013 07:39 am |
Regarding Point (1) in 3.6.8; what am I meant to be looking at as I'm positioned in the UCM Mapping window but cant see any differences?
Update: Sorry ignore that (need my first wakeup coffee!) I assume in the response wizard.
JulianLast edited on Saturday Apr 27th, 2013 07:44 am by juwi_uk
Posted: Saturday Apr 27th, 2013 09:18 am |
The update in Comfigurator help will normally be after a few days
