Comfigurator 3.5.6 error/termination on run
 Posted: Thursday Nov 15th, 2012 09:13 am
idheath
I've just upgraded 3.4.4 to the latest version and I get this error when I run the app.
System.IO.DirectoryNotFoundException: Could not find a part of the path 'C:\ProgramData\Cytech\Comfigurator\ifr'.
at System.IO.__Error.WinIOError(Int32 errorCode, String maybeFullPath)
at System.IO.Directory.InternalGetFileDirectoryNames(String path, String userPathOriginal, String searchPattern, Boolean includeFiles, Boolean includeDirs, SearchOption searchOption)
at System.IO.Directory.GetFiles(String path, String searchPattern, SearchOption searchOption)
at System.IO.Directory.GetFiles(String path, String searchPattern)
at Comfort.IrDatabase..ctor(String ifrDirPath)
at Comfort.Configuration.SetNonSerializedValues(SystemSettings systemSettings)
at Comfort.Configuration.Initialize(SystemSettings systemSettings, Boolean optimizeResponses)
at Comfort.Form1.SetNewConfiguration(Configuration newConfiguration)
at Comfort.Form1.NewConfiguration(String filename)
at Comfort.Form1..ctor(String filename)
at Comfort.Program.Main(String[] arguments)
I have looked in 'C:\ProgramData\Cytech\' and there is no 'Comfigurator' directory. (However there is a 'C:\Program Files (x86)\Cytech\Comfigurator 3\ifr" folder).
 Posted: Thursday Nov 15th, 2012 11:35 am
The installation may have been corrupted
Can you uninstall and re-install Comfigurator?
Did you change the Program file path during the installation?
 Posted: Thursday Nov 15th, 2012 02:52 pm
idheath
I didn't change the installation path during installation.
When i did the uninstallation, as per your instructions I noticed that I had version 3.1.9 installed in addition to the 3.4.4 version.
I've uninstalled both versions 3.1.9/3.4.4 and the latest version is working now.
Thanks.
 Current time is 04:12 pm
