Error when Reading from Comfort to Comfigurator
 Posted: Sunday May 13th, 2012 08:40 pm
idheath
I'm running version 3.4.4.0 of Comfigurator.
I did a "Transfer / Read (Comfort -> PC)" and selected the "Auto-generate names & response descriptions".
I get an additional error (file 1) then the read works OK.
Next when I try a "Save As" I get this error (file 2). Although "Save" works fine.
Attachment: Comfigurator Error 1.jpg (Downloaded 26 times)
 Posted: Sunday May 13th, 2012 08:41 pm
idheath
2nd file.
Attachment: Comfigurator Error 2.jpg (Downloaded 24 times)
 Posted: Thursday May 17th, 2012 06:23 am
The first message module does not support scan function means that one of the modules firmware is an older one which does not support the scan function. It should not affect the read function. You can upgrade the firmware using UCM and Comfigurator unless the module is KP03/KP04/KP05,  DP03 or RIO
Check the Modules Tab and see which module does not have any firmware information
For the 2nd error qre you using the latest Comfigurator 3.4.4? Perhaps there is a access issue by windows due to user authorisation to the folder?
 Current time is 08:05 pm
