Posted: Sunday May 2nd, 2010 08:57 am |
Posts: | 1200 |
Comfigurator 3.2.0 is now ready for beta testing.This new version has many new features and productivity enhancements as well as bug fixes and reduces Exceptions.
Bugs Fixed- For Phone Numbers to Dial Out, CMS Phone Types are now not allowed for valid for Phones 3 to 8
- Zwave Configurator Counter assignments were not displayed correctly
- IR Learner Utility in Windows 7 is now able to save the learned IFR file, see topic at http://www.comfortforums.com/view_topic.php?id=1827&forum_id=20
- Response Wizard for Cbus Action; if Remote Network Bridges are specified, these can now be deleted from the action, exceot by deleting the action
- Invalid IFR files in the existing IFR folder caused Comfigurator to have an Exception when the program is run.
Improvements
- Modules ID in Modules Tab can be swapped with other IDs. eg if UCM ID 1 is changed to 3, then the UCM at ID=3 is changed to 1 with a warning message. Note that this refers to the configuration settings, whereas the physical IDsmust be changed to match
New Features - CBus
- Added new C-Bus Action in Response Wizard: Stop Dimming
- Added new C-Bus Action in Response Wizard - Label (requires new Comfort firmware 5.190 not released)
Velbus
- Fixed Bug for Learning Velbus modules - when the number of modules is > 40, Read EEPROM error occurs
- VMB4PD module supports 2 pages of 4 buttons instead of 1 page
- VMB1BL and VMB2BL Switch Blind Off Command in Response wizard is supported
- Bug if Velbus module name has 16 characters. Keep the name to less than 16 characters
- Velbus Learn operation will not erase previous assigned counters and sensors
Known Issues
- Zwave Configurator does not work
- Scan Keypads does not show firmware version for KT03
- IR Receive Responses - if assigned to NULL, will call Response 255 if the IR signal is received. To workaround, do not use Response Number 255
- When Say Word Action is the last action in the Response, Comfigurator does not append another 255 to end the Response. hence if there are exactly 8 codes in the action including the 255 to terminate the Say words action, the Response will not terminate but continue into the next Response.. This is an existing bug even for older versions of Comfigurator. To work aorund, add a dummy action after the Say Word action.
- When Send RS232 Action is the last action in the Response, Comfigurator does not append another 255 to end the Response. hence if there are exactly 8 codes in the action including the 255 to terminate the action, the Response will not terminate but continue into the next Response.. This is an existing bug even for older versions of Comfigurator. To work aorund, add a dummy action after the Send RS232 action. Applies to CBUS and KNX actions
- When the name of an Alarm Type is changed, the Zone Types which trigger that alarm type still shows the old name until the Alarm Type for that Zone type is selected again.
- IR Transmit codes which have codes numbered near the end of the table ie 250 but which have gaps inn the IR numbers may overflow into the Alarm Types Table causing the Alarm Types to have the wrong information. Please use consecutive IR code numbers without any gaps
- Selective write may not be complete - the last line is not written to Comfort. Please use Full Write instead as a workaround. see http://www.comfortforums.com/view_topic.php?id=2197&forum_id=20 for full details
- The Alphanumeric Text ID feature does not work on Comfort Optimum UCM/GSM because of an error in the IOMAP.CYM file. Contact Cytech for the correct file
- For KT03 and Velbus Configurators, if a Response is referenced and the Response name is changed in the Responses page, the name change is not updated in the respective KT03 and Velbus pages.
- Reading a ccl file with Siren Duration < 1 second causes the siren Duration to be 0 resulting in an indefinate siren duration
- Reading a ccl file with less than 8 UCM will cause 8 UCMs to appear in the Modules Tab. The Numver of UCMs in Modules and Settings will not be 8. However when you change the name of a UCM or delete a UCM in the Modules tab then the number of UCMs in Modules and Settings will change to the wrong number.
Note that these bugs were present in older versions of Comfigurator, but not identified before
Posted: Thursday May 27th, 2010 04:35 am |
Posts: | 1200 |
Comfigurator 3.2.1 Beta is available for download from here
Please uninstall any older versions of Comfigurator before installing 3.2.1, otherwise an exception may occur
- Fixed Bug for Zwave Configurator wrong data in Learn Mode
- Fixed Bug in Velbus Comfigurator where if the Name of the module is 16 characters, an error results.
- Fixed problem in infrared codes ifr file where invalid characters cause exception
- Action 200 Open Door allows UCM ID to be specified (because of UCM/Access for Fingerprint Reader) in addtion to Door station
- Zone Settings - Property Virtual Input is checked automatically if KNX assigned Virtual Input to the zone and vice versa. The Zone Virtual Input property cannot be manually changed. Requires new iomap.cym file in attachment.
- Supports the new KT03 touchscreen Keypad
- If older version of Comfigurator is not uninstalled first, an exception is encountered
Known Bugs
- In KNX Configurator, if a KNX group address is made a Virtual Input, the corresponding zone has the Virtual Input setting checked automatically. But when the Group address is deleted or changed to another Type (other than Virtual Inputs), the zone remains as a Virtual Input and cannot be changed to assigned to another Virtual Input.
- The previous version must be uninstalled, before the new version is installed, otherwise an exception will be encountered.
- In Velbus Configurator, only 256 Velbus channels can be learned, so if a network has more than a total of 256 channels configured, the network cannot be learned even though all the channels are not needed to assign to Comfort counters, so the needed channels must be manually added instead of learned. This is not a bug, but a limitation
- Various bugs in KT03 configurator
Please copy the attached iomap.cym into the Comfigurator > config folder to replace the existing file - this is to allow the Virtual Inputs feature to be seen
Attachment: iomap.zip (Downloaded 12 times) Last edited on Wednesday Nov 3rd, 2010 02:16 pm by
Posted: Friday Aug 20th, 2010 04:47 am |
