Comfigurator 3 in Options > Use Configuration Connection settings checkbox
If this box is unchecked, it allows you to specify the UCM connection setting as Serial (RS232), USB or Ethenet depending on the UCM used.
If the option box is checked, the UCM connection settings are not shown (see above). The connection settings will be set to the last connection settings in Configuration > General Information (below)
The last connection properties shows the last time of write to Comfort, and the UCM Interface used, and either IP address and port, USB port or COM port
In the same screenshot above, you can also see in File Properties, the Comfigurator version used and creation time of the file
This is a very useful facility for installers who program customers systems.
However installers should be careful that when they write to Comfort at their office to test the program the last connection settings will be overwritten, so in such cases they should make a copy of the file for their own testing
