Posted: Tuesday Jul 21st, 2009 01:08 am |
Posts: | 5498 |
Comfigurator 3.0.8 (Beta) is available for download from here
This supports the new UCM/KNX announced in http://www.comfortforums.com/forum12/1533.html
It also fixes the following bugs from 3.0.1- Conversion of file from .ccl to .cclx with Concatenate CBus checked will in the field being unchecked
- In Sunrise/Sunset Times, any changes in the Location or country/city are not written to Comfort in Selective Write when Sunrise/Sunset Times checkbox is selected. A full Write must be selected
- In Sunrise/Sunset Times, if the Location/Country/City is not selected and there is a full Write to Comfort, Daylight savings offset of 60 minutes is written to Comfort. To prevent this, always select a Location or City
- When writing File System 31 (Comfort II OPT), every zone is automatically announced when opened. Those who do not want this "feature" please revert to Comfigurator 2.2.3 for the time being
- In Dynalite Actions, the Preset number increments each time the Response is saved
- "Use Configuration Connection" Settings is not working correctly
- Dynalite Recall Preset Action causes exception
Posted: Wednesday Jul 22nd, 2009 08:58 am |
Posts: | 5498 |
Although Comfigurator 3.0.8 has not been officially released, it has been tested and can be used quite safely. The known issues are listed below, mostly to do with the new UCM/KNX tab- In the UCM/KNX Tab, when you select KNX to Comfort with no KNX group addresses, an exception occurs. Ignore this and continue
- In UCM/KNX Tab, Reset to Default resets the UCM/KNX instead of restoring the UCM/KNX default settings (blank)
- UCM/KNX KNX to Comfort Tab, the assigned Counters and Sensors do not show as referenced in the Counters and Sensors screens
- KNX Action in Response Wizard to send EIIS5 telegram does not work
- When a cclx file is double-clicked to open it, Comfigurator opens behind the folder window (minor)
- When a second instance of Comfigurator is opened while a first instance has not been saved, the message saying "the (1st file) has been recovered" This means that the contents of the first file being worked on was recovered
Posted: Wednesday Jul 29th, 2009 01:18 am |
