Version 3.0.0.0
Firmware Type - Comfort II Ultra
File System 34
UCM Type - 10
Version - 5.079
Issue - Tried to dowload the attached configuration file. In this process, it fails with a pop up window stating that "Error writing configuration"
FYI, I am using USB to serial com port (prolific) and I do not have any issue using this converter with the previous version of comfigurator. And I noticed that for the new comfigurator, we do not need to keyin the engineer pincode. Am I missing somewhere? I have also included the UCM I/o monitor for your reference.
UCM I/O Monitor
> LI****
< LU01
> UL000003
< DL00000305FF22D7
> V?
< V?FE054F222001
> v?
< NA
> v?
< NA
> v?
< NA
> v?
< NA
> v?
< NA
> U?
< U?0A054F
> SR01
< OK
> DT20090313113319
< OK
< DT20090313113319
> DL00000205FFFA
< OK
> DL00031C010507080302040E11130B1715141610001B120A0C091C1D19181F004B
< NA
< NA
< NA
< NA
< NA
> LI
< LU00
Shah
Attachment: Ti CH Dsara CH.cclx (Downloaded 4 times)
