Posted: Saturday Jun 7th, 2008 04:00 am |
Posts: | 5493 |
We are making the new version of Comfigurator 2.9.x Beta available for testing by interested users for download and testing from here
- The beta version is 2.9.x; the final released version will be 3.0
- The new version requires the Microsoft .NET Framework 2.0. If it is not already installed, the CF installation will download and install it.
- The new version will coexist with V2.2.3 and uses a different settings mechanism so will not interfere with existing Registry settings for 2.2.3.
- Files can be read either in the old format (.ccl and .cct) or the new format (.cclx and .cctx). They can only be written in the new format currently.
- Note the new style of the Monitor I/O window below the main window, not a separate window.
- All program options except Select Default Template are in the Options>Settings menu option.
- Both Tools menu options are supported.
- Toolbars can be customised under Options > Settings
- Last Connection Properties and Installer Details added in Configuration > General Information
- Where relevant, the tooltip feature for displaying Comfort address values has been replaced by a field in the status bar which shows the address and value (e.g. see Modules & Settings>Number of Keypads).
- The window layout for each individual screen is saved so that you can optimize each layout to suit the amount of data etc.
- There is an extra feature on the Zones/Inputs and Outputs screens – checking the Show Status option will display the current status of all inputs or outputs.
- Printing is not supported yet
- Help file not updated yet
- The final options for Engineer Code or User Code entry for download have not been implemented.
- If with AND and OR conditions are possible
- Zwave and HDL UCMs are supported in Names > UCMs
This is a major change and with many features not fully described yet. It is safe to install it without affecting the current Comfigurator 2.2.3. However do not use it for live systems. Comments and feedback on this forum please
CytechLast edited on Tuesday Sep 30th, 2008 08:47 am by admin
Posted: Friday Jun 13th, 2008 12:25 pm |
TheMax74
Posts: | 247 |
First issue:
The "Select Default Template" form, appears behind the splash screen, and we can't select the combobox items, without using a workaround (task manager to switch to the form)
Second:
I find a new set of modern icon, instead of old VB style icons, will have more "appeal"
Old icons are intuitive, but makes your job little retro'.
More to come...
Using Vista SP1
Posted: Sunday Jun 15th, 2008 07:37 am |
Posts: | 5493 |
We have not been able to duplicate this with Vista but the next version will have changes so this will not occur.
Posted: Thursday Jul 24th, 2008 07:07 am |
Posts: | 5493 |
The new beta version of the next generation Comfigurator 2.9.2 is available for testing. Please download from here
The older version 2.9.1 should be uninstalled before installing this version
This version includes:
- "Require Engineer Code to Download" in Modules & Settings > Configuration Flags. When uploading or downloading for the first time in a session. Comfigurator will first ask for User Code to read the value of the Engineer Code Flag setting. If Engineer Code is required, Comfigurator will then ask for Engineer Code (F0 will be required). This allows Installers to program with User code for convenience and set to "Engineer Code Required" when programming is completed if he wants to restrict the customer from reprogramming the system.
- Auto-save implemented
- Import items from other configuration file (including Tuning). This currently only allows import of items which have no dependencies on other items.
- IFR codes now included in cclx file
- Printing
- Bug-fixes and other minor changes
The main missing items are the Help file and conversion of CCLX to CCL
Known Bugs
- Selective Download causes crash
Posted: Friday Jul 25th, 2008 08:09 pm |
palmlodge
Posts: | 507 |
Loaded up my 2.x config out of curiosity.
It shows , in red, and error in all responses that have "invalid keyword: keypad 1 broadcast enable"
also
invalid syntax: x10 a4 dim 4 (lots of these in different responses)
also
response name not present in configuration : Do AmpOff
but this responses does exist and works in the current config
Posted: Saturday Jul 26th, 2008 03:01 am |
namnp
Posts: | 35 |
I just tried and found that within CF V2.9.2.0:
1- There is no Output names 65 to 128.
2- When you change the name of an Output - let say Output 129, after hit Enter or Mouse Click, the screen always back to beginning - i.e. start from Output 1 onward, instead of maintain or display the next Output (for convenience of changing the next Output name for example)
Posted: Saturday Jul 26th, 2008 05:05 am |
Posts: | 5493 |
Thanks for the feedback. These will be fixed in the next release
Outputs are from 1 to 64 for Comfort and Slaves, and 129 onwards for SCS/RIO outputs. There are no outputs from 65 to 128 in Comfort at present
the point about the Outputs screen resetting to the beginning should also be fixed
Posted: Monday Jul 28th, 2008 02:16 pm |
palmlodge wrote: Loaded up my 2.x config out of curiosity.
The X10 command format "X10 A4 DIM 4" is not a valid action anymore after Comfort 4.97. The actions doscumentation states;
____________________________________________________
Dim and Bright command format from Version 4.23 to 4.96: 195,66,5,137 DIM for 4 cycles to ¡®B5¡¯. No of cycles x 32 = 128 + 9 = 137(for v4.23 to v4.97)
From 4.97, the Dim and Bright commands have been changed. Action 109 is used to set the number of repeat cycles for the Dim and Bright commands, instead of embedding the repeat cycles in the Dim/Bright Command. This new method allows up to 32 dim or bright repeat cycles to be implemented, instead of just 7 with the old method.
E.g. To dim A5 by 10 cycles using the new method, use actions
109,10 (set no. Of cycles to 10)
195,65,5,9,255. (X10 A5 dim)
---------------------------------------------- You must have started your ccl file a long time ago. I doubt that the X10 Dim 4 command would be wrking as expected in your current firmware which is quite up to dateLast edited on Tuesday Dec 23rd, 2008 11:31 am by admin
Posted: Tuesday Jul 29th, 2008 07:11 am |
palmlodge
Posts: | 507 |
Just an FYI - I dont use those X10 commands.
What I Do use tho is :
And that as listed above gives errors. I use this to silence the keypads when arming to night mode etc.
Posted: Tuesday Jul 29th, 2008 01:06 pm |
Posts: | 5493 |
The Invalid Keypad Broadcast Enable problem has been identified and wil be fixed in the next beta
regards
Posted: Sunday Aug 24th, 2008 03:30 am |
Posts: | 1200 |
The new version of Comfigurator Beta 2.9.4 is available
All the features have been implemented and known bugs fixed
Support for Enocean and Miracle/HDL have been implmented in UCMs
Posted: Saturday Sep 13th, 2008 06:20 am |
Posts: | 5493 |
Comfigurator Beta 2.9.5 is now available
This fixes bugs from previous versions
Posted: Tuesday Sep 30th, 2008 08:48 am |
Posts: | 1200 |
Comfigurator 2.9.6 is now ready for download, with more bug fixes
Posted: Thursday Nov 6th, 2008 01:00 pm |
Posted: Thursday Nov 6th, 2008 04:56 pm |
koutsogiannis
Posts: | 40 |
The issue Comfigurator 2.9.x Beta, I can say that corrected many details as the ease of reference in planning, especially when the installer had volume (automation facilities)
What I need to add is that the installer time plans to perform test of the mandate. Example: Send X10 - IR or to hear from keyboards the tone horn chosen.
These broadly. I believe that this publication will help a lot
Posted: Thursday Nov 6th, 2008 11:20 pm |
Posts: | 5493 |
If I understand you correctly, you would like to be able to send the X10 and IR and simulate the siren sounds when you do programming
You can do this by Using the Execute Response function where the Comfort system will do the response you have programmed, including Xx10, IR and activate the siren type chosen. You will still need to do a download though
Posted: Saturday Dec 6th, 2008 06:23 pm |
17th Post |
Hi everyone,
I downloaded the Beta 2.9.6 from the website today and tried to install. My Avast virus checker said it was infected with a trojan so I aborted the install. Downloaded it again just to be sure and same happened again.
I tried the 2.9.7 from this thread and it's ok.
Suggest you might want to check 2.9.6 yourselves but I'd say it could well be suspect!
Posted: Sunday Dec 7th, 2008 03:03 am |
18th Post |
Posts: | 5493 |
Strange, I just checked with Zone Alarm antivirus and it did not report any infections. What was the trojan reported do you know?
I have removed the old links, as 2.9.8 will be out soon
Posted: Sunday Dec 7th, 2008 08:57 am |
19th Post |
Avast reports it as "Win32:Trojan-gen {Other}". Could be Avast being over-sensitive to the setup.exe file but it thinks its a virus/worm. Build 2.9.7 doesn't do this so must be some difference between the builds at least.
Posted: Tuesday Dec 9th, 2008 11:36 am |
20th Post |
Posts: | 5493 |
I suspect Avast is a wee bit sensitive. Let us know if it happens for future versions
regards
Current time is 11:47 am | Page: 1 2 3 |
