I need help for DM02 Door
 Posted: Thursday Aug 28th, 2014 08:29 pm
hasan hadi
HI
please can be any one explain about DM02 Door
1- i need wiring
2- how can programmed by using Comfigurator
Hasan
Attachment: door.png (Downloaded 22 times)
 Posted: Friday Aug 29th, 2014 10:00 am
Please download the DM02 manual from the website, see http://www.cytech.biz/dm02_manual.html
Each one of our products has a manual, which you can find from http://www.cytech.biz/manuals.html
If you have any questions on wiring or installation, please go to that site to llook for the relevant manual which will provide all the information
If there is anything you do not understand or require additional information then this forum is the correct place to ask
 Posted: Friday Aug 29th, 2014 10:23 am
hasan hadi
ident wrote: Please download the DM02 manual from the website, see http://www.cytech.biz/dm02_manual.html
thank you siryes I reading maunal and have some eq.1- the DM02 using only one door or more 2-can be connected door station directly to comfort without using DM02 if yes how connect it?3-if have more from 3 door station what doing because i know max door station connected to comfort is 3 4- this standard or notthis from manual "" the ID for thedoor station (49 for ID 1, 50 for ID 2, and 51 for ID 3). "" i mean number 49,50 ,51
5- please can give me example how programmed door station one and more from one
 Posted: Saturday Aug 30th, 2014 07:34 am
you need 1 DM02 for each DS01 or DS02 door station. when you buy DS01 or DS02 bundle the DM02 is included
Only DP03 plastic door station can be cnnected to Comfort without DM02
But this can discolour when installed in the hot sun and rain so DS01 or DS02 is preferred
Max door station is 3
4- this standard or not this from manual "" the ID for the door station (49 for ID 1, 50 for ID 2, and 51 for ID 3). "" i mean number 49,50 ,51
ID is 1, 2,3
49, 50, 51 are the numbers when the door station is reported in the evvent log
Ignore this for now
You do not have to program the door station
You need to set the IDs to 1,2,3 if you have 3 door stations
Then use Comfigurator and Scan for modules so it can find the 3 door stations, then write to Comfort. The 3 door stations will then work
 Current time is 07:44 am
