Comfort Automation/ Security System Forums > Products > Door Stations > Door station cannot hear or be heard
 Posted: Tuesday Jun 5th, 2012 02:52 am
davids
I have had Comfort I Ultra for a number of years and used to be able to operate microphone audio with the Comfort door station. Now when somebody presses the doorbell the phone rings, the microphone light comes on the keypad but there is no audible communication between the keypad and door station.
I have referred to the doorstation manual and seen the references to locations 118 and 119. I have tried to increase the value in location 118 from 25 to higher values with no effect.
Inter keypad communication works OK using microphone .
 Posted: Tuesday Jun 5th, 2012 03:26 am
If the communications used to work and you have not changed the parameters, then it is unlikely that changing parameters will improve it
It is probably dye to a faiuty doostation microphone or microphone wires to Comfort
You say communications is not audible but can you hear the Keypad on the door station? is is it one way which is the problem, ie door station mic cannot be heard?
Then that is what you need to investigate
 Posted: Wednesday Jun 6th, 2012 02:08 am
davids
The person at the door cannot hear anything. The microphone light comes on and the person speaking at the keypad cannot be heard by the person waiting at the door.
 Posted: Wednesday Jun 6th, 2012 02:44 am
It looks like a fault on the door station or the mic/speaker wiring connecting the door station to Comfort
 Posted: Wednesday Jun 6th, 2012 02:54 am
davids
If nothing can be heard in either direction doesn't that mean we have two issues at stake here rather than just one to do with the microphone on the door station?
 Posted: Wednesday Jun 6th, 2012 03:05 am
It
You mentioned that Keypad to Keypad communications is fine in both direction?
Hence Comfort itself is handling the speaker and mic from the keypads correctly
You say that it was working for a number of years. Hence the problem still lies with the door station or the interconnecting wiring and this is what you should investigate
Try disconnecting the door station from its mounting and directly connect to Comfort with a short wire and see if the audio can be heard
 Current time is 08:39 pm
