DS02 and Comfort 1 compatibility
 Posted: Friday Sep 3rd, 2010 08:26 am
mbailey
Can someone possibly confirm that the DS02 is compatible with Comfort 1 and also whether DM02 module is required or not?
Thanks, Mark
 Posted: Friday Sep 3rd, 2010 09:13 am
DM02 is a substitute for DP03 or DP01 so in theory it should work with Comfort I. However we must say that this has not been tried yet
We wil do some tests to confirm
 Posted: Tuesday Oct 5th, 2010 07:17 pm
mbailey
Did you have any luck with confirming compatibility?
Thanks, Mark
 Posted: Wednesday Oct 6th, 2010 12:53 am
Sorry we forgot to update you. DM02 is compatible with Comfort I. DS02 includes the DM02 and Ringer module
 Posted: Wednesday Oct 6th, 2010 07:06 am
mbailey
That's great, thanks very much for your help.
 Posted: Tuesday Oct 18th, 2011 12:14 pm
ianh100
Can I just clarify this compatibility? I have comfort 1 with the original door station and ringer module. I would like to replace the door station with a CityMax unit, can I just buy the DM02 module? will my current ringer module still work?
I do plan to upgrade to Comfort 2 soon so dont want to buy any hardware that only works with Comfort 1.
 Posted: Tuesday Oct 18th, 2011 12:38 pm
Yes you can buy a DM02 and the Fermax and use it with Comfort I
Your ringer module can  still be used
When you upgrade to Comfort 2 (which is highly recommended) you will need to get a RGR05 as your old Ringer will not work with Comfort 2
 Posted: Saturday Oct 29th, 2011 11:30 am
ianh100
Hi, I see that the Citimax door station can use AC or DC power. is it possible to use the 12volts DC from Comfort rather than installing an additional transformer?
I am not planning to use door opening feature. Is the issue just the ammount of power that is drawn from Comfort? I have a COmfort 1 Ultra, UCM ethernet, RGO3 and a single keypad.
Many Thanks
 Posted: Saturday Oct 29th, 2011 12:28 pm
One of the reasons why the DMO2 was introduced was to in-effect isolate the door station comms form the Comfort alarm (comforts with doorphones connected directly in remote locations did seem to suffer from spikes when there was a lightening strike etc).
Using the same power supply for both devices would (in my opinion) not be recommended.
I can recommend DIN rail mounted supplies - inthis way you could use the same mains feed and mont the transformer and doorstation equipment neatly in a consumer unit.
A
 Current time is 02:17 pm
