Comfort Home Automation/ Security System Forums > Products > Door Stations > Use of DM02 with Panasonic PBX doorphones
 Posted: Monday Jul 26th, 2010 11:59 am
  PMQuoteReply
gaynorc
Has anyone any experience of using the Comfort Door Station Interface DM02 with Panasonic PBX Door Phones (e.g. KX-TES824 / KX TA824)?
If so, the DM02 manual cautions that "Some third party intercoms will not turn on their audio path until their in-house handset is off hook. If DM02 is used with this type of intercom, a means to simulate the handset going off hook and on hook is needed so as to allow the mic and speaker on the intercom to be activated."  It outlines how to do that.
At a guess this might be the case in PBX situations.
Can you advise whether the Panasonic system does or does not turn on the audio path as mentioned in the manual, and if so how you handled the work around?
Thanks in advance.
Back To Top
 Posted: Tuesday Jul 27th, 2010 01:59 am
  PMQuoteReply
I doubt if the Panasonic Doorphone is an analog type, ie that it has speaker,  mic, doorbell press signals as separate wires which can be connected to the DM02.
If you have any connection diagrams for this doorphone, send it to support@cytech.biz so we can take a look
Back To Top
 Current time is 08:57 am
