UCM/Cbus 2 Firmware 7.054 to 7.106
 Posted: Saturday Dec 16th, 2017 12:41 pm
UCM/Cbus2 7.054
  1. Fixed Bug - Enable and Trigger Group addresses did not update the mapped Comfort Counters
  2. Fixed Bug - sending commands to Trigger and Enable groups by Response wizard did not update the mapped Counters
  3. Fixed Bug - changing counters in Comfort mapped to Enable group addresses did not send the change to the Enable group. Now this allows commands to be sent to an Enable group by changing the value in the mapped counter
UCM/Cbus2 7.068
  1. Sending Flag value mapped to cbus group address will take effect even if the flag state is not changed.
  2. Improved firmware upgrade so boot sector may not be updated if there is no change
  3. Improved firmware upgrade so it may work even if UCM/Cbus is reset during upgrade
  4. If counter change originates from ucm/cbus, comfort broadcast counter change will be ignored by ucm/cbus to avoid the endless feedback and change when slow dimming by cbus2. This improves slider on app
UCM/Cbus2  7.106
  1. Fixed occasional problem initial zone state transmitted to C-Bus Security application zone status may not be updated
  2. Improved Monitor Mode for cbus soo that messages  Received from Cbus and  Transmitted to Cbus are displayed. Previously, only message from Cbus are displayed. This requires Comfigurator 3.12.2 (not available yet)
  3. Work-around for rare problems for some C-Bus networks where the C-Bus serial interface was not able to receive a full status reply for the Lighting Application and hence was not able to initialise resulting in the ERROR led remaining on. Cbus2 firmware will not go into Smart Mode even if the Status Reply is not received from Cbus Lighting application
 Current time is 06:10 am
