UCM/Cbus2 v7.052/7.054
 Posted: Saturday Jul 5th, 2014 06:36 am
The new 7.052 (Beta) firmware has the following changes
Fixed a problem when messages are sent from a remote network via a Bridge, that causes the initialisation commands to be sent to Cbus. This causes the lighting status to be requested so that groups which are dimmed (level 1 to 255) cause the mapped counter in Comfort to change to 255.
The bridged cbus command now does not cause a cbus to be reinitialised, instead it is ignored if the cbus mesage is meant for another network
If the cbus is reinitialised due to an unexpected state of the SIM, it will not request the Lighting status again so the problem of counters changing to 255 when the lighting is dimmed will not occur
Known Issues
Enable and Trigger application map to counter does not work
Firmware can be downloaded from http://www.cytech.biz/ucmcbus2_firmware.html
 Posted: Thursday Jul 31st, 2014 09:09 am
UCM/Cbus firmware 7.054 (Beta) has the following changes;
  1. Fixed Bug - Enable and Trigger Group addresses did not update the mapped Comfort Counters
  2. Fixed Bug - sending commands to Trigger and Enable groups by Response wizard did not update the mapped Counters
  3. Fixed Bug - changing counters in Comfort mapped to Enable group addresses did not send the change to the Enable group. Now this allows commands to be sent to an Enable group by changing the value in the mapped counter
 Posted: Tuesday Aug 5th, 2014 06:34 am
UCM/Cbus2 firmware 7.054 has been released
Upgrade in Comfigurator by right clicking on the UCM/CBUS2 in Modules and selecting "Check for Updates"
An Internet connection is needed
 Current time is 06:52 am
