UCM/Cbus 5.216
 Posted: Friday Aug 20th, 2010 07:04 am
  • Fixed Bug Day of week in time sent to C-Bus was wrong
  • Fixed bug - Time from Cbus to Comfort did not set the seconds value
  • Sends Text Label Cbus command for DLT switches
  • This firmware UCM 5.216 printed on a label on the U1 IC on the baseboard is not compatible with SIMs labelled 1223/7, 1223/4, 1151/1. Compatible with 1477/1 and ST7 version of the Cbus processor on the plug-in daughterboard. The ST7 version is shown in the photo below .   Do not upgrade to 5,216 for non-compatible Cbus processor versions
Bugs
  • Sending commands to other applications besides Lighting will update the counter related to the group address.
Attachment: Cbus5_216.zip (Downloaded 13 times)
 Posted: Friday Aug 20th, 2010 03:57 pm
Chiu,
I have a 1223/5 as well so I assume that will also not be compatible.
I do have one of those new SIM's as shown in the picture but how can I see that it's the ST7 version? There are no markings on the board itself.
 Posted: Saturday Aug 21st, 2010 02:21 am
The new SIMs are all of the ST7 version. There may be  no version marking
At the moment the main advantage of the new firmware is the text label command
It may be possible to get an upgrade at a nominal cost for thise =who have the old version
 Posted: Tuesday Dec 21st, 2010 12:12 pm
Pgordon
slychiu wrote: The new SIMs are all of the ST7 version. There may be  no version marking
My CBUS UCM has been in place for several years, (I forget how many, but at least 3 or 4), and hasn't had a firmware upgrade since I got it... (not had any compelling reason to, since most thinkgs have worked perfectly)....
Now I do need to get some of the new features/functionality, and I'm guessing that the vintage CBUS-UCM I have will most likely be too old to support this new firmware.... :(
Is the underlying UCM mainboard the same? - i.e. is it only the CBUS module that has changed? - If so, can I just get a replacement CBUS module without replacing the whole UCM?
Cheers.
Paul G.
 Posted: Tuesday Dec 21st, 2010 12:20 pm
If your UCM/Cbus looks like the one in the first post, thenit is a second generation one whose firmware can be upgraded
If yours has a big square IC in a socket, marked CBUS 5.99 or below then it is the first generation type whose firmware cannot be upgraded by using a UCM and Comfigurator
 Posted: Tuesday Dec 21st, 2010 12:53 pm
Pgordon
Thanks Chiu,
I'm not at home now so I can't check, - and honestly, I haven't looked at it for such a long time that I couldn't possibly say which type it is from memory... - although I definitely do recall that it has a daughterboard just like the one in the picture in the first post...
Fingers crossed...
Paul G.
 Posted: Thursday Dec 23rd, 2010 05:41 pm
Pgordon
Nope, - mine has a big square IC in socket marked CBUS 5.75, and the CBUS daughterboard is marked 1223/5 so I guess I'm out of luck...:(
 Posted: Thursday Mar 17th, 2011 02:47 pm
Please note a bug has been discovered
Eg when you send a command to Cbus Trigger application at group address 1 to 255, then Counter 1 will change to 255 as well. The Counter should only be updated by the Lighting application
This will be fixed in the next firmware version
 Current time is 10:49 pm
