UCM/Cbus 5.208
- Security Armed State will have values 1 to 4 depending on security mode instead of common 1 when armed.
- If zone is bypassed at UCM/Cbus reset, this is reported to to Cbus.
- Multiple Cbus messages can be received and handled.
- Existing Line cut, AC Failure and low battery alarms are notified to C-Bus when C-Bus is connected to Comfort.
- Zone states are reported to Cbus when Cbus is connected
- Faster initialisation of Cbus interface especially when the Security Application is not present on the C-Bus (eg C-Touch)
- Fixed bug when Cbus addresses > 128 not reported correctly
- Added STOP ramp SAL command, handle Label DLT message
- Messages to C-Bus larger than 45 bytes (concatenated messages) are aborted in keeping with the Cbus serial interface spec.
- Security Application Password Good/Bad supported
Bugs- Sending commands to other applications besides Lighting will update the counter related to the group address.
Note: UCM/Cbus firmware 5.208 and below not work with new Cbus SIM Daughterboard with ST7 micro pictured below
This firmware UCM 5.208 and below should onlybe used with SIMs labelled 1223/x, and 1151/x as shown below
Attachment: CBUS5_208.zip (Downloaded 1 time) Last edited on Thursday Mar 17th, 2011 01:45 pm by
