Posted: Thursday Sep 20th, 2018 03:37 pm |
richylloyd
I have towel rails in my bathrooms which are connected to the central heating (independent system) but they also have an immersion heater for summer use. This part is controlled by Comfort.
I'm trying to improve my controls as I can't detect if the central heating is on and whether to enable the immersion heater or not.
I was looking to sense the mains signal voltage from the specific central heating circuit (it is multi zone) but I can't seem to find a simple means of achieving this.
A simple 220V relay connected to a RIO input seems like the solution but I can't find such a device.
I would prefer to purchase a simple unit rather than creating my own.
Surely someone else has had such a need and has a simple solution to offer?
Posted: Friday Sep 21st, 2018 06:28 am |
Posted: Friday Sep 21st, 2018 08:00 am |
richylloyd
That only provides the output which I already have.
I'm looking to sense the state of the central heating circuit via the mains signal from the respective thermostat/control valve.
Posted: Friday Sep 21st, 2018 08:17 am |
Swiss-Toni
What is the amperage, you may get away with using TWS02 or use a current sensor CSM03
Posted: Friday Sep 21st, 2018 08:31 am |
richylloyd
I'll check on this but as it is only a signalling voltage, I suspect it is almost nothing.
Posted: Friday Sep 21st, 2018 12:17 pm |
Posted: Friday Sep 21st, 2018 12:23 pm |
Posted: Friday Sep 21st, 2018 02:34 pm |
richylloyd
thanks, those relays are some of the ideas I will look at - they just seemed like overkill (and a bit large) for the job I was asking them to do.
I was hoping there was a very low power, compact version for interfacing with a RPI or similar.
I'm hoping to use the CSM03 once I check the current load.
I have also found the following kit which drives a LED. Possibly I could replace the led with a RIO input as it is around 3V.
https://quasarelectronics.co.uk/Item/velleman-mk181-ac-power-voltage-led-indicator-kit
Posted: Sunday Sep 23rd, 2018 05:33 pm |
richylloyd
So, the current draw on the mains signal line is only 8mA (3mA idle). I'm going to struggle to get the CSM03 to read this without multiple loops through the sensor which I don't think is possible.
I've tested the LED indicator circuit and this was not successful either.
Looks like I will try and find a suitably small 220V relay to activate the RIO input.
Anyone have awareness of such a product?
Posted: Monday Sep 24th, 2018 01:07 pm |
CSM03-CT and PCB connected to Comfort input will not be able to detect small currents
But if you use IRIO01 with ISM03 or an IRIO-TWS these have current sensor inputs that directly connect to a CSM03-CT and allows you to set thresholds donw to a few milliamps
see IRIO at http://www.comfortforums.com/forum129/4328.html
Posted: Wednesday Sep 26th, 2018 08:59 pm |
richylloyd
Thanks, That IRIO01 seems a very useful future addition to consider.
I'm proceeding with a mini 240V relay which allows me to get a reading without a load (useful in my case).
