IR receive codes reference issue
 Posted: Sunday Mar 1st, 2015 07:00 pm
Pharris15
I am playing around with RIO and IR remote commands and I noticed that I have used IR command 0 but the "Show References" is empty but the graphical references shows the actual links. Also the text is not in blue.
Ultra 7.065
Attachment: No show references.JPG (Downloaded 12 times)
 Posted: Monday Mar 2nd, 2015 04:47 pm
"Show References" is supposed to show where the item selected is referenced
You have assigned the Response "IR 1 to Output 1" to IR Code 0. However there are no references to IR Code Received Code 0 because in general IR Receive Codes do not have references, or other places that refer to IR Receive Codes
It is the Response "IR 1 to Output 1 " which is referenced by IR Code 0, not the other way round
The Graph References do show IR Code 0 but that is showing IT Code 0 referencing the IR Response, not something else referencing IR  Code 0
Graph references is more useful as it shows links upstream and downstream to the selcted item
Attachment: irGraph.jpg (Downloaded 10 times)
 Current time is 11:49 am
