Two away modes possible or not?
 Posted: Thursday Jan 31st, 2019 07:31 pm
111rdw
Guest
I want to have two away modes. One with all sensors active and one with a pir off. Dogs in the house. I know I can disable one but that’s a lot of button presses. Ideally I would like the day button to be the same as away but one pir off.
 Posted: Friday Feb 1st, 2019 01:24 am
You can use Day mode for the one where the dog is in the houseAsign the PIR as a zone type 5 which is Immediate in Away and  Night ModesWhen you arm to Day, the zone in zone type 5 will not cause alarm
However when you arm to Day Mode, you are not required to exit, so the system willl arm after the Night Exit Time (default 5 seconds) even when tyou are in the house
Another method is to reprogram the Day Mode key to another Response, as all function keys can be reprogrammed in Control > KeypadThis new response is Bypass Dog zone, then Key arm to away
 Posted: Friday Feb 1st, 2019 08:35 am
111rdw
Guest
thanks
 Current time is 06:40 pm
