Dial-out test questions
 Posted: Thursday Jul 27th, 2017 03:32 am
Wimphot
In http://www.comfortforums.com/forum16/4412.html
there are directions for Dial-testing over the PSTN.
Q/. 1 When I click Initiate Dial Test
as below:
Does this just just dial out on phone number 1 or, as I have found when using F,3,3,
does it dial all numbers programmed?
I tend to modify/test my Comfort late in the evening and there are some people whose numbers I have programmed whom I do not wish to disturb at 24:00hrs
Q/.2 Is there a way - other than by pulling the twisted pair off the TEL-IN terminal, that I can test the dial-out function of my ucm2gsm.
(useful as it would stop me getting messages from my network provider saying I have not used my number for a while).
AND
Taking this one step further; how would I set up an "Action" that will - on a regular basis - initiate a test voicecall over the GSM network?
 Posted: Thursday Jul 27th, 2017 08:11 am
Initiate Dial Test is the same as F3,3 on the keypads, it dials to all the Phone numbers in the Dial Test Alarm Type 27
if you want to restrict dial test to some phones only, you can change the Phones listed in Dial Test Alarm
Alternately, use another unused alarm type eg CMS Test alarm (Type18) which is normally for dialing to a Central Monitoring system (CMS) or alarm receiving centre (ARC)
enable the phones that you want to dial to
Response CMSTest does a dial test to this alarm
Use a Time Program to call the CMS Test Response
 Posted: Thursday Jul 27th, 2017 10:02 pm
Wimphot
Slychiu
Thank you
 Current time is 03:26 pm
