window opener
 Posted: Wednesday Aug 26th, 2015 06:41 pm
bagushandhoko
anyone has experience programming such motor in the attachment ? i try to use blind function but not work as expected. the window only open 2 cm for 2000 ms, vice versa closing function. ?
so i also try to use manual programming by putting pulse output 254 time but the window only open or close 80 % .  Other alternative is using toggle output , but i dont know  How to program toggle output for certain time ( by timer ) ?
and if using blind function , could i program master command for 1 floor in order control all windows in same time`
Attachment: PhotoGrid_1440598967915.jpg (Downloaded 35 times)
 Posted: Wednesday Aug 26th, 2015 06:48 pm
bagushandhoko
master command like this
Attachment: Untitled.jpg (Downloaded 36 times)
 Posted: Wednesday Aug 26th, 2015 07:15 pm
bagushandhoko
is the program attached right for "toggle output 10 seconds"
 Posted: Thursday Aug 27th, 2015 06:58 am
The programming is wrong
"If secs > 10 " is NOT a delay, it means if the seconds portion of the  time is > 10
you need to use WAIT for a delay See topic on Timers
http://www.comfortforums.com/forum92/4062.html
Before we can advise  how to program this, we need to know exactly what is it you are trying to control, and what is does
A more detailed explanation is necessary or instructions for the device
 Posted: Thursday Aug 27th, 2015 12:47 pm
bagushandhoko
devices : window opener AC motor type
cables input :  blue ( common/N ) , brown ( open ), black ( close )
to open : powering brown ( connect to L )
to close : powering black ( connect to L )
there is no stop function
 Posted: Thursday Aug 27th, 2015 01:19 pm
How long is required to open or close the window?
Is there a limit switch that stops the motor when the window has fully opened or closed?
 Posted: Thursday Aug 27th, 2015 04:08 pm
bagushandhoko
21 seconds ( 254 X 50 ms ) only 80% open, close vice versa. So I think need 30 seconds
Yes there is automatic stop limit
 Posted: Thursday Aug 27th, 2015 05:26 pm
tech07
To turn on the outputxxx for 30 seconds
Output OutputXXX On
wait for30 seconds using timer 1
Output  OutputXXX Off
This shoould be enough time to open (or close)
 Posted: Thursday Aug 27th, 2015 05:59 pm
bagushandhoko
Haa.. its more simple than my program :D ( by creating response inside response like in the attachment )
and next question  :
1. how to create master command for one floor ?
2. which command to protect that close command can not execute before open finish ?
Attachment: Untitled.jpg (Downloaded 27 times)
 Posted: Friday Aug 28th, 2015 05:59 am
Create a response for each windoweg
Window 1 OpenWindow 2 OpemWindow 3 Open
Createa Respnse to open all windowsDo Window 1 OpenDo Window 2 OpenDo Window 3 Open
etc
 Posted: Friday Aug 28th, 2015 06:39 am
bagushandhoko
I see....  this response can be associated to icon master command at KT03 ?
Last question ... command for waiting open process finish before able to activate closing ?
bagushandhoko
 Posted: Friday Aug 28th, 2015 11:49 am
13th Post
answer to both questions is yes
 Posted: Friday Aug 28th, 2015 03:27 pm
14th Post
bagushandhoko
the 2nd question ...how ... :?
BTW i just upload the program with " set output On " command...rly01h become not respond ... it respond with "active pulse active" command ... Am i missing something ?
my program same as :
Output OutputXXX On
wait for30 seconds using timer 1O
utput  OutputXXX Off
please see the acttachment
Attachment: Untitled.jpg (Downloaded 21 times)
 Posted: Friday Aug 28th, 2015 04:24 pm
15th Post
The command are correct, but there is something wrong with the slave 2. It may not be connectedCheck the connections and modules
 Current time is 03:30 pm
