Access your Comfort with a UCM/USB
 Posted: Tuesday Jan 15th, 2013 11:11 pm
cab123
there is a really simple way to connect to comfort via network without having to get a dedicated UCM/Ethernet. It is really useful to connect iphone app or program with comfigurator without having to be in the same room.
What you need:
UCM/USB
some hardware that runs linux. You can get a PC, a RPi or a router with ddwrt. I tried all and RPi is what i currently use.
1. Get in the cli and install socat
sudo apt-get install socat
2. Connect the usb cable from the UCM/USB to the PC
3. Find the name of your FTDI usb driver using
dmesg | grep FTDI
On this case ttyUSB0 is the location, you should change to wharever you find.
4. run the command:
socat -v tcp-l:1001,reuseaddr,fork /dev/ttyUSB0,raw
You shoud have the PC listening on port 1001 and sending all packets to the serial connection. the -v option is to see the actual communication.
You can now connect for example the comfigurator prog and set up a connection setting the IP address of your PC and the port = 1001.
When you're done abort with ctrl+c
5. append to the end of the file /etc/rc.local (before "exit 0") the command so it will activte upon boot
/usr/bin/socat tcp-l:1001,reuseaddr,fork /dev/ttyUSB0,raw &
6. reboot the PC and you should be done. Confirm the command is woking by issuing a
ps -ef | grep socat
7. Connect your IOS App or comfigurator and have fun
Caveats:
IR learner doesn't work
Let me know if it works for you
Cab123
 Current time is 12:23 pm
