How to use Timers
 Posted: Thursday Nov 26th, 2009 12:11 pm
Note that there is a new and easier way to introduce delays between actions, see  http://www.comfortforums.com/forum92/4062.html
Comfort II Ultra as 32 user Timers which can be used to implement delays from a Response to another.
The format of the Timer action is as follows;
"Do Response X after Y seconds using Timer Z"
This means that Timer Z (1 to 32) is started for a duration of Y seconds (1 to 65534 seconds) at the end of which, Response X is activated
Important:
Note that the Timer action merely starts the timer, the action does not wait for the timer to expire, for example
Response 123
Output 1 ON
Do Response 200 after 60 seconds using Timer 20
Output 2 ON
End of response
Response 200
Output 3 ON
End of Response
When Response 123 is activated, Output 1 will turn on, Timer 20 is started, and Output 2 is turned on. This means Output 1 and 2 will appearr to turn on almost simultaneously.  Output 3 will turn on after 60 seconds
Some may have the wrong idea that Output 1 turns on, then after a delay of 60 seconds Response 200 is activated, then only output 2 turns on. This is incorrect.
There is no delay by actions within a Response. All actions are executed one after the other
There is a topic  on how to Flash lights during an alarm in http://www.comfortforums.com/forum83/1681.html
This is a good example of the use of timers and how useful they can be.
Attachment: TimerAction.jpg (Downloaded 273 times)
 Posted: Friday Nov 27th, 2009 01:25 am
Another important thing to know is that there can only be one instance of a timer running at any time. if you  use a timer you will stop the timer if it is already running
For Example, the Response
Do Response X after 20 seconds using Timer 1
Do Response Y after  10 seconds using Timer 1
Do Response Z after  5 seconds using Timer 1
will result in Response Z after 5 seconds. Response X and Y will not get activated because Timer 1 is restarted and reloaded with Response Y in the second line, and then immediately restarted and reloaded with Response Z in the 3rd line
If the intention is to do all three Responses after the delays then use different timer, eg
Do Response Y after  10 seconds using Timer 2
Do Response Z after  5 seconds using Timer 3
 Posted: Friday Nov 27th, 2009 01:34 am
Checking if a Timer is Running
You can check if a timer is running in the Response Wizard
eg
If Timer Timer05 <> 0 Then
    Do Response..
End If
TimerX <> 0  means the timer is running
TimerX = 0 means the timer is stopped
Attachment: If Timer.jpg (Downloaded 388 times)
 Posted: Friday Nov 27th, 2009 01:37 am
Stop Timer
You can stop a timer using the Stop Timer Action. This prevents the Timer Response at the end of the timer from working
eg, a Response starts a timer
Do Response X after 60 seconds using Timer 20
If before the timer is finishethe response below is activated
Stop Timer 20
This stops the timer 20 and hence Response X will not work
 Posted: Thursday Aug 9th, 2012 08:09 am
surmall
Got it
 Posted: Saturday Aug 11th, 2012 08:12 pm
palmlodge
Ideas for future releases
1. A Pause command so you don't have to create many many responses
2. A user "Any free timer not running" option rather than choosing one
 Posted: Sunday Aug 12th, 2012 02:29 am
How would you use the pause command? What does it pause?
"any free timer" - you dont really save much time by not selecting a specific timer?
Do you have an example of what Response you are trying to write?
 Posted: Tuesday Jun 25th, 2013 09:00 pm
srooks
Is it possible to set the duration of a timer from a counter? I'd like to be able to vary the duration of a timer, based on the input from a KT03 slider control.
S
 Posted: Wednesday Jun 26th, 2013 04:39 am
There is no action to do this, but I will ask the R&D if it can be done in the future
 Posted: Wednesday Jun 26th, 2013 06:54 am
TheMax74
I think PAUSE means to suspend response execution for xx seconds. Like a Threading.Thread.Sleep in response code.
 Posted: Wednesday Jun 26th, 2013 11:34 am
But a  Response cannot be paused. It always executes the actions and finishes. It may start a timer, but it does not wait til the timer finishes before going to the next action. A Timer action is started, then the timer is left to run  until it expires, when the Target Response is executed
 Posted: Monday Nov 25th, 2013 05:50 am
clubpenza
casino online holiday palace sbo
 Posted: Monday Nov 25th, 2013 11:26 am
13th Post
No, currently that is not possible
what application do you have in mind and why do you find that to be helpful?
 Posted: Wednesday Jan 15th, 2014 11:35 am
14th Post
srooks
You asked for an application .. in my case this would be the duration for running a sprinkler. I'd like to be able to set this duration via a KT03 slider.
 Posted: Monday Jan 20th, 2014 08:02 pm
15th Post
siamak
Is it possible to do that with a response that increase/decrease a counter which is compared to zero, and two timers triggers the responses of -let it be called- countdown?
in this case the counter will be decreased by the timered responses to the point which the sprinkler runs.
 Posted: Wednesday Jan 22nd, 2014 04:33 pm
16th Post
I could not really figure out what Siamak  was suggesting.
Possibly it would be a good idea to set a timer value from a counter, and more convenient for the user, we will look at this possibility
 Posted: Friday Jan 24th, 2014 02:39 pm
17th Post
siamak
Sorry for my bad explanation, here is what was i suggesting.
Set slider (Counter000) min/max value to 20 and 100
assume that Zone02 OnResponse is SprlnklrCntDwnStrt
SprlnklrCntDwnStrt:
Copy Counter Counter000 To Counter001
Clear Flag Flag01
Do SprnklrCntDwn1
SprnklrCntDwn1 :
If Counter Counter001>= 100 And Flag Flag01 = 0 Then
   Do SprnklrRun
End If
Get Counter Counter001
Add Immediate 5
Set Counter001
Do SprnklrCntDwn2 After 2 Seconds Using Timer01
SprnklrCntDwn2:
   Do SprnklrRun
End If
Add Immediate 5
Set Counter001
Do SprnklrCntDwn1 After 2 Seconds Using Timer01
Assuming an Abort switch on Zone03, Zone03 OnResponse would be AbortSprnklr
AbortSprnklr:
Stop Timer Timer01
Clear Flag Flag01
Here we have max of 32 and min of 0 seconds from Zone02 Activation to sprinkler run with 2s steps, these could be changed by simply changing the slider min/max value and 2 sec expiration times of SprnklrCntDwn1 and 2  Responses or changing the Add Immediate value. Also it could be a timer between SprlnklrCntDwnStrt and SprnklrCntDwn1 (by Do After Timer Expires) to add a fixed time before sprinkler run.
Note that if in the project it is possible for Zone02 to go Off and  On in a short time, which could be in count down time, there would be consideration to avoid repeating the countdown from start and extending the time to run the sprinkler.
Also there would be a "Time Extending" button on the keypad, simply triggering a response which sets counter001 to a fixed value.
 Posted: Saturday Jan 25th, 2014 06:07 am
18th Post
Thanks for such a detailed response
 Posted: Wednesday Dec 24th, 2014 07:41 am
19th Post
Is it possible to set the duration of a timer from a counter? I'd like to be able to vary the duration of a timer, based on the input from a KT03 slider control. S
Actually this is already possible
In the action Do Response x seconds using Timer, if the number of seconds is =0, then the last action value is used as the delay. See the example below.
Get Counter Counter003
Do Response after 0 seconds using Timer01
This means that the delay is taken from Counter 3 instead of a fixed value in the action
 Current time is 05:01 pm
