RIO Firmware 2.0.0 to 2.0.6
 Posted: Saturday Jun 14th, 2008 05:44 am
  • 2.0.6 (Dec 2007) Supports Pulse Output action. Previous versions do not support Pulse Outputs
  • 2.0.4 (March 2007) CBUS2 IR Codes supported, mapped in IRReceive codes 0-31. Adjusted IR Receive algorithm to match new IR Receiver characteristic.
  • 2.02 (May 2005) Fixed Bug in previous versions where noise on an input may cause the RIO to lock up until the input is triggered again
  • 2.0.1 (June 2004) Fixed IR Transmission can transmit IR 0 to 255. Fixed bug could only transmit 0-15
  • 2.0.0 (Dec 2003) - Upgraded processor. Transmit IR 0 to 15 only. IR Transmit buffer increased from 64 to 96
The Firmware history is also documented in the RIO Manual
 Posted: Sunday Nov 8th, 2009 12:33 am
segurant
The temperature sensor in the SCS I think it is not good solution. Is necessary included an SCS for to access the temperature sensors. An excellent solution I think is the creation of a new RIO (RIO02) with 8 inputs and 8  outputs analog (0 - 10V), so we can place sensors of temperature, light, humidity, etc..
Best Regards
Miguel Antunes
 Posted: Sunday Nov 8th, 2009 01:53 am
Lets move this topic to the RIO forum http://www.comfortforums.com/forum84/1669.html
 Current time is 08:10 pm
