Posted: Wednesday Apr 15th, 2020 12:50 pm |
Posts: | 5499 |
Bugs Fixed- Fixed intermittent problem with firmware upgrade using UB02 in reset preventing firmware upgrade by Comfigurator
New Features- UCM sensor fixed bugs for fractional value
- Sensor report sr and sensor reply s? send 3 bytes fractional value of sensor
- RS485 receive message if (ucmpartition) = 0ffh, accept all partition broadcasts
- When UCM/ETH03 is logged out set no ucmpartition at so eth03 can send emails for all partitions
- UCM receives and process all partition broadcasts, check is match to UCM partition.
- Added d? query and dR report
- Support wifi01 submodule plug in for UCM and CM9001, automatic detection and set 38400 baud
- UP, DP commands supported. dont include event log
- UP send progress UPxxxx whhere XXXX is address 0400H boundary. DP send prgress DPXXXXevery 0400H addresses
- UP for ETH03 will time out more than 2 minutes because no receved data from CF but it completres if idle time out in CS Manager is set to 5 minutes
- U? add parameter SS 3 = wifi01
- Added Timer report TRttVVVV only when UCM is logged in Supports Register Monitor for Timers.
- UCM log out sends LU00 so that CM knows when ucm is log out and TR message is not sent
- UCM counter: when external device updates counter, dont update local UCM counter, sebd counter change to CM, and when CM broadcasts new counter value, then udate CM local counter so if the update counter nessage RS485 is missed, the counter update is stil sent later Fixed probem sometimes modbus counter was not updated
- UCM log out will see LU00, will not have LUFF following.
- RS485 Transmit Buffer ize incraesed from 500 to 600 bytes
Posted: Thursday Apr 16th, 2020 11:33 am |
Ian
Posts: | 249 |
I scanned in Comfigurator. It tells me 7.119 is the latest!
Posted: Thursday Apr 16th, 2020 11:36 am |
I bet Chiu has forgotten to update the software update xml file with the new version! 😉
Posted: Thursday Apr 16th, 2020 12:11 pm |
Posts: | 5499 |
Sorry it should be updated now
Posted: Saturday Apr 18th, 2020 08:56 am |
