UCM 7.098
 Posted: Monday Apr 3rd, 2017 04:37 pm
UCM 7.098
Changes from UCM 7.076
Known Bugs
  1. COPY Button set ID could not set to maximum 8 From UCM 7.072 Bugs Fixes
Bugs Fixed
  1. Fixed bug UCM/ETH03 upgrade by cable fails 1st time Allow LT to be received without login so UCM can reply OK, not NA.
  2. Fixed BUG from UCM 7.075. for Sensor commands  s!NNVVVV if repeated same value ucm replies NA. s? gave wrong reply
  3. Fixed bug F!nn03 toggle reply FL was wrong. Bug From UCM 7.060
Changes
  1. Increased message size of rs485 messages to 140 bytes
  2. When UCM reports a sensor value, and Comfort broadcasts the new sensor value, the original reporting UCM ignores the sensor value in order to prevent multiple racing commands
  3. UCM sends output command to Comfort only if output changed
  4. Messages S? BP, DI, EV, O? A? I? a? DT, FL  will not be sent to PC unless logged in
  5. Support H! and H? Commands for HIO
  6. Support EL command
  7. Login add partition  (0-3 or FF),
  8. use "Nonascii hex" method for Vocab Upgrade depending on Comfort firmware
UCM 7.098 has been released
Please upgrade
 Current time is 12:34 am
