Posts: | 5493 |
Bugs Fixes
- Fixed bug UCM/ETH03 upgrade by cable fails 1st time Allow LT to be received without login so UCM can reply OK, not NA.
- Fixed BUG from UCM 7.075. for Sensor commands s!NNVVVV if repeated same value ucm replies NA. s? gave wrong reply
- Fixed bug F!nn03 toggle reply FL was wrong. Bug From UCM 7.060
Changes- Increased message size of rs485 messages to 140 bytes
- Speed up erasing of EEPROM for Write to UCM/EEPROM by erasing in blocks
- When UCM reports a sensor value, and Comfort broadcasts the new sensor value, the original reporting UCM ignores the sensor value in order to prevent multiple racing commands
- UCM sends output command to Comfort only if output changed
- Messages S? BP, DI, EV, O? A? I? a? DT, FL will not be sent to PC unless logged in
- Support H! and H? Commands for HIO
- Support EL command
- Login add partition (0-3 or FF),
