UCM 7.075
Fixed a bug found in certain combinations of modules where Comfigurator logs in and gets an NA reply during the initial queries. Firmware released
Known BUGs
COPY Button set ID could not set to maximum 8 From UCM 7.072
If an empty message is sent to the UCM serial port (by Comfigurator or other software), it will cause the UCM to hang. The UCM must be reset
UCM 7.076 fixes the bug in 7.075 where the entry of a message with no content causes the UCM to hang.
This is not likely to occur using Comfigurator or other software like Comfortclient or the Comfort mobile and tablet apps. However the firmware should be upgraded nevertheless
